Can anyone post a pic of the drivers side deck lid latch, that is under the chrome bezel... My latch works but is missing the lever to release the pin, and I am trying to locate one or have one made...TIA!
The latches are the same with the exception of being right and left. You should be able to use the pin on the RH latch as a pattern for the left side.
so it should be like an image in the mirror, I had one made exactly the same as the passenger side and could not get it to work..Any ideas were I can buy this?
here's a pic of the left latch that i purchased from corvette central p/n 543045(L). not sure if you can can just buy the lever part
That's exactly what I was looking for, thanks a bunch... going to be looking at corvette centrals website for this...might as well order the whole assembly new..
