Floor jack question
Old Sep 17, 2006 | 12:36 PM
IMA 66's Avatar
IMA 66
Default Floor jack question
I have a Craftsman 3 ton floor jack. It is not very old at all and the last few times it creaks and lowers a little on its own a little bit each time it creeks. It has a little cap wher eit looks like oil can be added and it says oil on it. Question is what kind of oil do i use and will this correct the problem? I can't find the manual for it so wasn't sure wha tto put in it.
Old Sep 17, 2006 | 12:41 PM
moosie982's Avatar
moosie982
I use hydraulic oil, I have used ATF in a pinch. I dont know if it will correct your problem but its worth a try, just be sure to add oil with the jack fully lowered. I use an old squirt can to slowly add the oil. Hope this helps you,,,Peace,,,Moosie
Old Sep 17, 2006 | 12:44 PM
GUSTO14's Avatar
GUSTO14
Any good auto parts store (NAPA, Advance, Autozone, etc.) carries hydraulic jack specific oil. It is not much more than any other quality oil, and that's what I use. I believe AmsOil even carries a synthetic specific for jacks, I use their synthetic compressor oil in my air compressor and it definitely runs cooler.
Good luck... GUSTO
Old Sep 17, 2006 | 03:29 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Default Hydraulic oil
Use hydraulic oil, do not use tranny fluid, power steering fluid or the third option people use which is brake fluid. I have seen all three used and the end result will be that the seals will deteriorate over time. The jack may work initially but the rubber seals will not hold up to anything but hydraulic fluid. As stated above, you can buy hydraulic jack fluid in any of the auto parts stores.
Old Sep 18, 2006 | 01:16 PM
IMA 66's Avatar
IMA 66
thanks guys i'll pick up some hydraulic fluid and give it a shot. Hope that is what's wrong with it. I have another jack that is a no name one that i bought probably about 15 years ago. It has sat outside and is rusty and nasty but it still works Although i don't use it since i never liked the actuation of the release for it.
Old Sep 18, 2006 | 02:09 PM
Philvet's Avatar
Philvet
The creaking sound and fact that jack goes down very slowly its a bet the seals are leaking. If you have the model #, should be on the jack. You should be able to get new seals for it.
To Floor jack question
