vin number question
Old Sep 19, 2006 | 03:31 AM
rabiddawg's Avatar
rabiddawg
Default vin number question
can i tell from the vin number if i have an early69 or late 69?
btw vin is S30133 last 6 digits
also where is the plate for the body color, place of mfg. etc?
i have one on the camaro on the firewall but cant seem to find the corvettes
Old Sep 19, 2006 | 04:17 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Google is your friend: http://www.idavette.net/facts.htm
That serial number can't be from a '69, according to that page.
Old Sep 19, 2006 | 04:27 AM
rabiddawg's Avatar
rabiddawg
194379S700001 through 194379S738762
69 vettes
mine is194379S30133
ive been told by other vintage vette owners that looking at the options it was kinda rare.
radio delete. 350 HP 350 cu inch motor with factory aluminum valve covers.
i also found out the rear is 3:93
wish i had found a definative source for all the info on this car.
also where else can i find the VIN?
I got those numbers from the dash on the drivers side.
Old Sep 19, 2006 | 06:17 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
69 vettes
mine is194379S30133
You're missing a "7" in the VIN you typed.
You have the 30133rd 69 made. Pretty late.
The VIN will tell you nothing about the options.
No 3.93 rears available. 3.70 maybe. 3.55 or 4.11 maybe??
The trim plate is located on the front door jamb on the drivers side door. Open the door and look in the front. It was riveted on. Was not be painted originally, but it could have been painted over if the car was redone.
That tag will have the ext color and interior trim, as well as the "body built date code" stamped into it.
What specific thing do you want to know? Chuck
Old Sep 19, 2006 | 07:45 AM
rabiddawg's Avatar
rabiddawg
hmm the number is exactly that on the drivers pillar post?
once i find the tag ill bug ya for more info.
thks!
Old Sep 19, 2006 | 07:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...also where is the plate for the body color, place of mfg. etc?...
54-80 Corvettes were assembled at St. Louis, Missouri. 81 Corvettes were assembled at St. Louis (most) and Bowling Green, KY. Since 82, all Corvettes have been assembled at Bowling Green.
Trim Tag is on the driver's door hinge post. It will list the factory codes for the original interior trim color, exterior paint color, and the time/build date (upper right corner of the tag).
Your '69 was probably assembled in September, 1969.
Old Sep 19, 2006 | 07:54 AM
Easy Mike's Avatar
Easy Mike
[QUOTE=rabiddawg]hmm the number is exactly that on the drivers pillar post?/QUOTE]
Check again. You should find 194379S730133
1 Chevrolet Division of General Motors
9 Corvette
4 V8 engine
37 Coupe (67 for convertibles)
9 Year of manufacture (1969)
S Plant code for St. Louis
7 Car line series for Corvette
30133 Consecutive unit number
To vin number question
