76E and 76L
Old Sep 19, 2006 | 09:45 AM
hayman's Avatar
hayman
Default 76E and 76L
Can anyone tell me how to determine if I have a early or late model 76?
Bill
Old Sep 19, 2006 | 09:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Post your VIN. "Early" and "Late" typically apply only to running changes made during the model year. To further confuse matters, "early" and "late" can refer to more than one calendar date during the production run.
Old Sep 19, 2006 | 10:35 AM
seventysixvette's Avatar
seventysixvette
To muddy the waters a little more, sometimes you have to take early or late dependant items on a individual basis. If the factory was in the middle of the change over, they'd clean out the parts in the bins before switching over. I got into the early or late issue with my radiator mount and fan shroud.
John
Old Sep 19, 2006 | 02:53 PM
BenUK's Avatar
BenUK
I got a thread running here:
http://forums.corvetteforum.com/show....php?t=1386200
You can check your VIN against the list and find out whether your car's early, late, or somewhere in between.
If you post your VIN at the bottom I'll add it to the list of '76s that forum members have posted.
Old Sep 19, 2006 | 05:16 PM
rodesmg's Avatar
rodesmg
depends on the part. my 76 was built in march and took an early rad---go figure
Old Sep 19, 2006 | 07:48 PM
Vet76te's Avatar
Vet76te
The 3 most prominant changes are;...
Early 76 had rear view mirror mounted to roof line. Late 76 had mirror glued to windshield.
Early 76 had the smaller "CORVETTE" letters recessesd into thee rear bumper. Late 76 had a larger "CORVETTE" script that was not recessed.
Early 76 had interior light mounted only in floor board area and very rear compartment. Late 76 had a roof mounted interior light in the middle of the T-Top bar added.
Other issues of change were the radiator support and the deluxe door panel trim changed.
Old Sep 20, 2006 | 02:38 AM
BenUK's Avatar
BenUK
My car, built in May 76, has the late rear badge and late rad frame/shroud, but the early interior mirror, no overhead courtesy light. It's a mixture. There's no clear date for a switch.
To 76E and 76L
