Preserving Build Sheet
Old Sep 19, 2006 | 04:29 PM
bbvette69's Avatar
bbvette69
Default Preserving Build Sheet
I am starting to put my 69 back together and am at the fuel tank stage.I was lucky enough to find the build sheet in decent order when i removed the tank.It is still stuck on quite good so i cant remove it but i want to preserve it.Any answer's????
Old Sep 19, 2006 | 04:51 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
verrrrrrrrrryyyyyyyy carefulyyyyyyyyyyy!!!!!!!!!!!!!
Old Sep 19, 2006 | 08:12 PM
Muddywaters's Avatar
Muddywaters
I removed mine with a very sharp razor blade. Just as soon as a razor blade began to loose its edge I chande it. I also used a razor blade handle so as to get leverage (to keep the blade between the tank and glue) work slowly!!! Muddy
Old Sep 19, 2006 | 10:09 PM
Sayfoo's Avatar
Sayfoo
Take a picture first
Old Sep 20, 2006 | 11:23 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
The very first thing I did was scan mine and copy it at different zoom levels and darkness levels. Old print/paper will continue to deteriorate and mine seems tougher to read today than when I pulled it. At least once its copied you have numerous copies.
To Preserving Build Sheet
