steering box leak
Old Sep 19, 2006 | 09:27 PM
doublearrow's Avatar
doublearrow
Default steering box leak
I posted in a thread about my car and mentioned having a leak in the steering gear box, and was told to use transx. I have transx, but will I have to bleed anything after applying this, and totally ignorant where on the gear box can this be added? Is it the top bolt on the right side? THanks in advance.
Old Sep 19, 2006 | 11:18 PM
...Roger...'s Avatar
...Roger...
I think if they recommended Trans-X they might have thought you were talking about the ps control valve.If your talking about the pitman arm seal at the bottom of the steering gear-I fill the gear with #1 chassis grease-remove 2 of the bolts in top of gear and remove coupler from your grease gun and insert threaded end in gear and pump it until grease comes out other bolt hole-check again in a week or so and do again if needed.
Old Sep 20, 2006 | 10:14 PM
doublearrow
Default thanks
Thanks for the information. Do you still think transx would do any good in the gear box. It's leaking fluid pretty bad.
Old Sep 20, 2006 | 10:17 PM
...Roger...
If it does help it will be temporary-trans-x just makes the seal swell with some kind of chemical
To steering box leak
