C3 Nose Rivets Question
Old Sep 20, 2006 | 07:26 PM
jroutt's Avatar
jroutt
Default C3 Nose Rivets Question
I just talked to a guy selling a 72 vert and he was discussing the repaint he just had done. He stated that the rivets were visible prior to painting and the problem was corrected by grinding down the rivets and glassing over them. Doesn't sound like this was done correctly but I have never seen it done. What do you guys think?
Thanks,
John
Old Sep 20, 2006 | 07:50 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
what rivets?
Old Sep 20, 2006 | 08:30 PM
jroutt's Avatar
jroutt
On the nose in front of the hood there are apparently factory rivets that attach the nose section on. At least that is what I have been told and I have personally seen C3s with bubbles across the nose indicating some sort of attachment. I am told that the rivets corrode and bubble up and that this requires major work to correct.
Old Sep 20, 2006 | 08:34 PM
SIXFOOTER's Avatar
SIXFOOTER
Hmm, depends on what else they did to fix it. Just gringing the rivits down and glassing them over will make the paint look nice, BUT, the headlight buckets might fall off the nose.
To properly eliminate the rivits, your supposed to put in a bonding strip (glued on the underside of the nose) and then glue the header bar to that. The headlight buckets attach to the header bar.
Old Sep 20, 2006 | 08:45 PM
JonnHeather's Avatar
JonnHeather
I agree. You have to fix the cause of the problem so it doesn't come back and cause more problems later...
Old Sep 20, 2006 | 08:46 PM
jroutt's Avatar
jroutt
Thanks. You have confirmed that this is not simply a cosmetic issue and I will question this guy more about what was done. By the way, this car is in Ft. Meyers Fl. Any chance of your being close by?
Old Sep 20, 2006 | 08:52 PM
SIXFOOTER's Avatar
SIXFOOTER
thats on the other side from me, but its not out of the question. Let me know if I can help. Might be another member over there somewhere
Old Sep 20, 2006 | 08:56 PM
crazywelder's Avatar
crazywelder
The '68-'72 cars had about 35 rivets that held the hood surround reinforcement to the hood surround panel. The reinforcement is the main attaching point for the headlight mechanism. The rivets were aluminum and the reinforcement was made of steel. Over time galvonic corrosion took place between the disimilar metals and the expansion of the corrosion causes bumps over each rivet or lumps in the paint. The rivets are sunken into the hood surround, so I doubt the rivets were ground away, they probably ground the corrosion build up away. The '73 and later cars did away with the rivets and the reinforcement is bonded to the hood surround. To convert to the later style is best to eliminate the corrosion problem, but not an easy job.
Old Sep 20, 2006 | 09:00 PM
roger55's Avatar
roger55
Everything you wanted to know about bumps is right here:
The Truth About Bumps
Old Sep 20, 2006 | 09:01 PM
jroutt's Avatar
jroutt
I appreciate very much the offer of help. The guy told me his bodyman said that the problem would likely return in a few years which says that the work could not have been done right. This is a 72 steel cities gray vert, base engine with 4 spd and no other options. He is asking 29,000 which says to me that this should be a perfect car. Knowing that the repaint and body work is suspect tells me that I should probably leave this one alone. What do you think?
Old Sep 21, 2006 | 12:09 AM
Chris Farrer's Avatar
Chris Farrer
When I bought my '72 it had been repainted about 7 years prior and had been taken back to bare glass. It was quite good but was showing some hairline cracks in the seams on the guards so I decided on a complete repaint. The rivets on the nose had been slightly sanded down and were nearly flush with the body. After two pack primer, paint, cut and polish they are not evident. It is possible they may reappear, one in the door sill has slightly cracked the paint. I am very happy with the smooth finish, having said that orange peel effect. I took mine to an NCRS meet to have the car judged this year and one comment was that the bumps from the rivets was not visible, if that's the only thing wrong with the car I'm not fussed.
I think someone said oxidisation of the rivet was a problem, has this car lived near the sea.
Old Sep 26, 2006 | 03:27 PM
SIXFOOTER's Avatar
SIXFOOTER
Boy that thing would have to be perfect for me to pay that, but I am cheap. And there is no reason to do the job cheap, get him down or pass.
To C3 Nose Rivets Question
