Wiper adjustment
Old Sep 22, 2006 | 08:10 AM
smbenn's Avatar
smbenn
Default Wiper adjustment
Yes, we've had our summer here in England so welcome back rain for the next 10 months... My wipers work fine but they sweep out beyond the window frame! How do you adjust the sweeping area on my 75 coupe?
Simon
Old Sep 22, 2006 | 08:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The assembly instruction manual (AIM) has a page outlining the procedure for this adjustment. Not sure, but it might also be in the chassis and service manual.
Old Sep 22, 2006 | 09:55 AM
smbenn's Avatar
smbenn
OK ,thanks Mike. AIM on order (your suggestion from last time I believe!) together with some other parts on back order. Erm, can anyone give me a hint in the meantime?!
Old Sep 22, 2006 | 10:03 AM
75 Red Vert's Avatar
75 Red Vert
- Mine is doing the same thing. Have only had this Vette for 3 weeks now.
Old Sep 22, 2006 | 11:20 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
I had this same problem, wipers would sweep past window and get stuck on my 68
I did two things first in the center of the car, where the wiper arm connects to the motor, there ar 4 bolts, two per side that you can loosesn, and then slide the wiper arms inboard to reduce the sweep.
second you could simply bend the wiper arms at the blades inboard for minor changes
cheers
tim
Old Sep 22, 2006 | 11:31 AM
75 Red Vert
Thanks much, Tim, will try it out tonight.
Randy
Old Sep 22, 2006 | 11:38 AM
sweethence's Avatar
sweethence
Randy
No sweat, is 4 botls by the way not 40
Old Sep 22, 2006 | 02:38 PM
Easy Mike's Avatar
Easy Mike
My advice is to follow the procedure in the AIM. Bending wiper arms is the last thing you want to do.
Old Sep 23, 2006 | 03:12 PM
luv2sail21's Avatar
luv2sail21
St. Jude Donor '05-'09-'10
Default Don't bend them
If you have to bend the arms.. you have some major problem. Possibly the wrong arms. The adjustment screws should take care of any adjustment.
Old Sep 24, 2006 | 03:17 PM
sweethence's Avatar
sweethence
Welll when i said bend the arms, I am only talking of tweaking them, the problem is that the moving parst are 37 years old on mine, and even full bringing them in was a little off, bending the last bit was easier that taking the arms off and repostioning them is all
cheers
tim
To Wiper adjustment
