Does anyone know of, or have they ever had the factory side exhaust covers rechromed?
Is there anyone out there that does this? I have a good set that need attention.
Any help would be greatly appreciated.
This is an ongoing question. I've heard that they're difficult to rechrome because the underlying surface is potmetal, and to do it correctly would require a special plating process before the chrome is applied. Apparently not many shops can do it, and it would probably cost more than a new set. Then you have to repaint the black stripes.
I would be interested in a solution as well. New ones are just way too expensive.
There's no real magic to plating pot metal - you just plate it with copper first like anything else. The big problem is bad pot metal castings that require tons of soldering to fix before you can start plating.
