light switch hot
Old Sep 25, 2006 | 05:47 PM
omc's Avatar
omc
Default light switch hot
I Have A 73 L48,ac,auto And My **** Is Gone On The Light Switch. My Concern Is That When The Headlights Are On For
Awhile I Can Not Hold On To The Switch Rod Because It Will Burn My Fingers. This Is No Joke. It Has Been Doing It Ever Since I Purchased It In Jan 06. Is This Normal Or Should I
Concerned? Should I Look At Changing The Swich Out? Has Anyone Had This Problem Or Is It Normal? I Know If The **** Was On I Would Not Have Ever Noticed It. Please Advise.
Old Sep 25, 2006 | 06:15 PM
CoolShark's Avatar
CoolShark
Be concerned. The switch should not be hot unless there is a short or some other excessive current draw. To much draw leads to melting wires, dash fires, etc.
Old Sep 26, 2006 | 09:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by CoolShark
Be concerned. The switch should not be hot unless there is a short or some other excessive current draw...
Yep. Be very concerned. Replace the switch.
Old Sep 26, 2006 | 09:44 AM
pws69's Avatar
pws69
Check out the RELAY thread in the Tech section. If you go that route, you will eliminate the major current flow through the headlight switch and may not have to deal with the switch at all. Don't get me wrong, I'd say the contacts on the switch are probably quite worn, but with minimal current flow, it won't be an issue until the switch just won;t work anymore. The heat (and danger) will probably go away.
To light switch hot
