Glove box lock
Old Sep 28, 2006 | 08:16 PM
pdege's Avatar
pdege
Default Glove box lock
How on earth do I go about removing the locking mechanism from the glove box door??
Old Sep 28, 2006 | 08:50 PM
moosie982's Avatar
moosie982
I am thinking that you need to put the key in the lock to depress the tumblers and then right next to the nut that fastens the 2 pieces together you will see a sort of tumbler looking thing (there is a sort of slot right there) and push that down with a paper clip or similar thing and the cylinder should come out. I hope that was clear enough for you to understand, look it over before you start, it should be clear as to what I mean,,,Good luck,,,Peace,,, Moosie
Old Sep 28, 2006 | 08:56 PM
...Roger...'s Avatar
...Roger...
OK its easier for me if I'm looking at it -open the door push the lock cam to the lock position and hold -at the base is a slot-in the slot is a tab -push it in with paper clip-slide out lock cylinder-unsrew outer flange -------(if this doesnt work then change the first step to hold lock cam in open position)edit after reading moosie's-I think depress the tab then slide key in and that will hold the tab in so you can remove lock--I think !!
To Glove box lock
