I've searched many previous threads, but I can't seem to find the answer I'm looking for. I have a 77 vette that someone before me did a very poor job of re-dying the interior trim panels. Before I prime and re-dye them correctly, I want to strip this old flaking dye off. Does anyone know of a chemical that does this well, or am I out of luck? Thank you.
Find a test area on the item that doesn't show - use paint stripper. Go slow - little goes a long way - stripper may "melt" plastic. I use the liquid - not jell. Sounds more like what was used was "paint" remember plastic needs to be prepped before dyeing - Mid-America (I keep telling everyone here - but no one listens) has a whole line of products for dying and preppping your interior. Also they have the correct shades of dye.
I appreciate the response. I've been aprehensive about using paint remover because of it possibly distorting the plastic, but i'll try an inconspicuous area. I have noticed that mid-america, as well as zip has a full SEM line and I plan on doing it correctly. thanks again.
Auto Spray Strip might be okay. It's a little less caustic than the thicker strippers. Test it first.
In a pinch, lacquer thinner would possibly work, but would take more work on your part.
Whatever you strip has to be thoroughly cleaned and prepped before you redye.
I am using Lacquer Thinner to wipe everything down before I dye. It is also taking off any dye, where I go back and work on an area. I am filling small blemishes with a leather patch and then redying over that. The lacquer thinner is slightly softening the vynal and seems to make the dye work especially well. I am using black so i just bought the brand that Auto Zone carries. One of the guys in there had done his jeep about a year before and it is holding up Great!. I am cleaning each piece very well and prepping it very carefully and so far so good. My stuff is turning out excellent. Another member told me about a glue and fill product called Pasco Bond and Fill. It also works excellent and has saved many pieces that have cracks etc. Good Stuff.
Ruthie
