Divorced Choke
Old Oct 2, 2006 | 08:15 AM
hayman's Avatar
hayman
Default Divorced Choke
Can someone explain what this term means?
Old Oct 2, 2006 | 08:33 AM
1stC3Vette's Avatar
1stC3Vette
A divorced choke set up is one where the choke plate is connected to a coil that is mounted to the side of the carburetor. As the coil heats up, the coil expands, opening the choke plate.
Good luck,
Dino
Old Oct 2, 2006 | 10:44 AM
JPhil's Avatar
JPhil
Sorry, but I beg to differ. The divorced choke has the bimetallic spring mounted on the intake manifold and operates the choke plate by a linkage rod. That's why it's called "divorced", the sensor/actuator is separate from the carb.
John
Old Oct 2, 2006 | 10:51 AM
noonie's Avatar
noonie
John
Old Oct 2, 2006 | 11:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It means lawyers were involved.
Old Oct 2, 2006 | 11:16 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
John
That is correct. There is a small tin housing under the carb, on the intake manifold by the #6 cylinder. the rod goes from inside that tin housing, straight up to the side of the Quadrajet carb. It's divorced because the bimetal spring is completely seperated from the carb.
Old Oct 2, 2006 | 11:50 AM
Milest's Avatar
Milest
I agree with JPhil
Milest's Avatar
Milest
I agree with JPhil
Old Oct 2, 2006 | 12:35 PM
427-390's Avatar
427-390
Good one!
Old Oct 2, 2006 | 12:37 PM
Kid Vette's Avatar
Kid Vette
JPhil has it right. Here's a pic:
To Divorced Choke
