Brake Master Cylinder Cap Replacement
Old Oct 17, 2006 | 01:16 PM
redvetracr's Avatar
redvetracr
Originally Posted by Durango_boy
I worked all last night and part of today on that Vette and didn't bleed once..
were you try changing a master cylinder cap.......
...redvetracr
Old Oct 17, 2006 | 01:20 PM
redvetracr's Avatar
redvetracr
Originally Posted by kdf1986
The other method would be to cut off the 1/4 tip from the end, and then rebend the loop 1/4 inch of the way up. That is risky because the loop is a cheap steel that will easily break.
kdf
cut the tip, rebend the loop???.....how about placing the sides of the bail in a vise and tap on the center with a SMALL hammer.....
...redvetracr
Old Oct 17, 2006 | 03:59 PM
kdf1986's Avatar
kdf1986
I tried that method too, and messed it up somehow.
Well, I didnt use a vise, but tried to steady it on the garage floor, and maybe that was my problem.
Thanks for the tip on this too. I have one more vette to try this on.
kdf
Old Oct 17, 2006 | 04:01 PM
Durango_Boy's Avatar
Durango_Boy
kdf
Vise method works. I had to do that on a Dodge master.
