High Test bad for 82s
You guys running 93 gas better not do that every tankfull. You run the possibility of burning a piston or valve in the process. Those 350's innerds were designed for optimal efficiency using regular juice. It won't hurt to use 93 once a month, as I do in my Vette, Charger and Mach 1, just to keep their vocal cords clean.
I'm looking for any of your comments on this...
Doubt that computer makes any difference on the 82 and octane it uses...
....Ok guys. As for a reallity check.
Yes running anything higher then 89 octane in our '82's will hurt your engine, foul up the fuel pump/filter, ecm unit runs car richer, maybe but not showen in tests might drop a cylinder and running the boost octane will not do anything but put lower emissions on the A.I.R. You say' Waste of money for the 93 octane and boost'??? YES... True and fact. Our engines where tested with 87 octane but as we all know it pinges our pistons on the up hills. I for one always run 89 octane for I hate the sound on my hills I drive. But as we all say' use your own judgement'.
OK this was my come back
Not meaning to start an issue over fuel octane.
However, I can find no warning about the use of higher octane fuels in the owner Manuel I do find many warnings about using only unleaded fuel. In fact, if you read Fuel Requirements in section 2-4 it states you should use an unleaded fuel with a rating of at least 87 octane.
Now in your defense it also states that using a higher octane rating than that which allows occasional spark knock is an unnecessary expense.
I see no warning from GM about a higher octane fuel creating any issues with internal parts...I also would like to know how octane would foul up a fuel pump or filter? as for the ECM it controls the fuel curve based on readings from the TPS, than the O2 after fuel is burned along with a few other sensors.
I guess I could go on but I will wait for a reply to this first.
Guess I have been fouling corvette motors for the last 30 years
trw
trw
And you might see a mileage improvement. I do.
And if your motor designed for a certain octane is pinging using that octane, then something is wrong. It needs to be fixed, not covered up with higher octane gas.
A RON87 fuel means that this fuel has the same auto ignition resistance as a 87% mixture of octane (this is a trivial name, it's a 87:13 vol% mixture of iso-octane and heptane)
Pure iso-octane has a rating of 100 on the octane scale, that's why it's used as a reference.
Remember in the states it's RON + MON/2
So our 87 is probably like RON91 and MON83, or something like that.
There are 3 rating systems, RON, MON (motor octane number) and PON, we have RON (research octane number) and you have PON (pump octane number) which is indeed (RON+MON)/2 .. I knew that
MON is always a couple of points lower than RON, RON looks better on the signs so that's why the thieving sumbiotches here sell us 95RON for 7$ a gallon or so
On top of that, your cheap gas has better quality control than our expensive stuff..we're being screwed over here
RON MON PON
90 83 86.6
92 85 88.5
95 87 91
96 88 92
98 90 94
100 91.5 95.8
105 95 100
110 99 104.5
The octane number is just chosen because of the " reference" fuel. N-heptane has a number 0 on the octane scale and iso-octane has a # of 100. That's why n-heptane is used to dillute the vol% to get a good reference without affecting the octane #. For instance a 91 PON (AKI) fuel is nothing more than a blend that tested to have similar ignition resistance as the 87vol% iso-octane reference fuel under the chosen circumstances (which differ for MON and RON, although pretty similar testing procedures)
