Is a # matching engine worth anything without the car? ( This may be a dumb question to some but take it easy on me please) There is a car for sale with a motor installed and the # matching comes with it. I don't want or need the # matching engine because i want to build the motor anyway. Thanks for the help!
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Take the matching # motor and travel on home. The motor makes the car worth the money. The motor without the car is just another motor. Purists will want that original motor and it's always a cool point especially if it's a desirable motor. Just my .02
I have my # matching block and heads 327-350 hp
But need alot of the bolt on stuff
The car has a hot Sb in it....but I have not had a chance to look at everything to see what was used from the original set up, just bought her this week.
What do you need for what you have?
Also I really need some better doors....vert.
I am a little cash poor after buying the car....be gentle
Kyle
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Acceptable ???
Originally Posted by DZRick
A correctly numbered motor and a numbers matching are two diffenert things.
If you've got a 68 as Kyle does and don't have the original motor a correctly numbered motor ( meaning another 68 corvette motor) is exceptable.
ACCEPTABLE is very generic, to a N.C.R.S or BLOOOMINGTON judge it is useless, wrong motor is wrong motor period, including if you ever want to retain big money for your car, a no match is a no match no matter what & reduces the value of EVERY CORVETTE..............FACT
with a sample exception of like a DRAGSTER, and an owner who just doesnt care. MOST DO....... ZIXXX PACKER
So what you're saying is: If I owned the Austrailian 68 L-88, and I put a rod through the block, the car is worthless? Even if when searching for a replacement engine, I was able to track down a complete engine that was identical except for the vin stamping. Do you still say the car is worthless? What if I went as far as to keep the old boat anchor that was dripping oil and antifreeze all over my floor? Still say it's worthless? I call on your theory. I would pay more money for say a '76 L-48 car that had a 572 in it than I would pay if it had an L-48. Modified cars are where the money is, unless it is some super ultra rare car.
A friend sold a CE big block for a large chunk of cash.
Some would say that is just as good.
# matching is kind of BS....I can make almost any # block you want.
Some would fool a judge.
My 63 was a misstamp and people acted like it was nom.
Not alot of the corvette parts have a vin derivitive....so its just a case of part # and date code hunting.
Examples lots of C1 are winning hi honors without the motors being the one Chevy put in.....they just look right
WORTHLESS vs REDUCED ????
DONT RECALL USING THE WORD WORTHLESS i stated REDUCED VALUE.............. NO B/S FACT !!
what is a CE block? my 71 454 vert has the correct date coded engine it is just not the original block, how much does it affect value? the heads an intake are date stamped 1 day apart so they may be the originals.
Last I heard was that as long as the casting dates were in line with the build date of the car being judged no points would be deducted for a nontypical stamping.
Read this in CorvetteFever a few years ago. FACT
CE, stands for something like "Chevy Exchange" motors replaced under warranty As far as how much it effects the value of your car. IMHO too much.
counter exchange = CE
It was on the warrentee replacement blocks
Some say on other motors you could walk in and buy.
If your vette blew up this is what chevy gave you.
Strictly speaking the engine is most valuable to the specific car whose VIN is stamped on the engine pad. Now someone with a similar year car might want that engine sinceit is a correct TYPE of engine for that model year car but it is NOT the engine that came in that car, so the VIN AND the engine suffix would have to be removed and restamped to make it correct for the car it is going into but strictly speaking it is a phony at that point.
Numbers matching usually means the engine that matches the VIN of the car it is in and that it is the engine that car left the factory with when it was built. Therefore in its purest sense any original engine only matches any one original car.
The "numbers" also refers to the casting code and to the date codes, in addition to the VIN and engine suffix codes.
Therefore your engine would only be "valuable" to whoever has the correct year car with the VIN that matches the one stamped on the engine (assuming it has not been 'doctored')
CE engines were not original equipment, (installed at the factory) and could be purchased at the Chevy parts counter and installed in anything.
Wow! Thanks for all of the input. The car is origional with the motor that came with it. I guess all of the codes will match. I will check into that. Thanks again fellow forum members!
could be a lot more $$$$$$$$$$$$$
Originally Posted by gator79
I read somewhere 3K to 5K for a NOM
check out some of the prices on big block tri power 67's they are exceeding $250,000 with documentation, that exact car is not reduced by only $3,000 to $5,000 ........with the wrong motor.......dont know how much less exactly, but
could very well knock it down to under $50,000 total value or less ?
any thoughts from the forum ?
Correct. The value added for the matching car/engine is proportional to the total value of the subject vehicle. I bet a guy with a '67 nom 427/435 would pay dearly for the original engine. Not true for a mid-'70's L-48.
