82 rear spring replacement opinions
Old Oct 15, 2006 | 01:27 PM
texaswilkins's Avatar
texaswilkins
Default 82 rear spring replacement opinions
I want to replace the rear spring in my 82 with a stiffer one. What do you guys think of the different rates available?
Bill
Old Oct 15, 2006 | 04:20 PM
rotgirl's Avatar
rotgirl
Just removed the #315 composite spring in my '79 and installing a #340. Like the way the comp. reacts more swiftly than the steel.
rg
Old Oct 15, 2006 | 08:41 PM
rastadr's Avatar
rastadr
i went with the vb dual mount spring. no lie , it takes less than 1/2 hour to change the rate from too soft to ultra stiff.
Old Oct 16, 2006 | 12:02 AM
MN-Brent's Avatar
MN-Brent
The way I see it, the suspension systems are designed to be balanced. If you up the rear, you should consider upping the front to bring neutral handling back to the car.
You could end up with oversteer/understeer situation if not done right.
See this for some reading material: http://wiki.corvettefaq.com/index.php?title=Suspension
Old Oct 16, 2006 | 12:54 PM
XLAR8R's Avatar
XLAR8R
rg
i agree, i like the composite a whole lot better then the steel.
Old Oct 16, 2006 | 01:35 PM
greyghost79's Avatar
greyghost79
installed a VBP #330 fiberglass spring two years ago. dramatic improvement in handling. you'll probably want to replace shocks. VBP sells shocks made to be compatible with composite spring. ride tends to be a bit "bouncy" with fiberglass spring.
To 82 rear spring replacement opinions
