help with 75 coupe
Old Oct 22, 2006 | 07:55 PM
beachbumtroy's Avatar
beachbumtroy
Default help with 75 coupe
hey can 1 of u guys tell me what the reason is for the baffle in the gas tank of my 75 coupe? thnx bb
Old Oct 22, 2006 | 10:14 PM
Chandler's Avatar
Chandler
Hi. Gas tank baffles are supposed to make sure when you go around corners or jam on the brakes the gas doesn't slosh away from the fuel pick up.
Old Oct 22, 2006 | 10:31 PM
beachbumtroy
Default gas tank
thnx i didnt know what they were for i thought maybe something to do with a rear end collision or something. thnx again bb
Old Oct 23, 2006 | 12:25 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...you sure you're not talking about the "bladder", as in "rubber fuel tank bladder"??? There are no "baffles" in a '75 Corvette fuel tank.
Old Oct 23, 2006 | 12:29 AM
Topless75's Avatar
Topless75
My '75 had a bladder that collapsed. Removed it and all is well. Perhaps his collapsed and, when he's looking in the tank, it looks like a baffle.
Or, he has a fuel-cell!
Old Oct 23, 2006 | 12:38 AM
Paul Borowski
...mine's been out since '94 and has been perfect since. I know of several '75-'77 owners whose cars will only take 12-14 gallons of gas when completely empty. Mine was like that until the Fall of '94...
Old Oct 23, 2006 | 03:06 AM
jdmick's Avatar
jdmick
There was a small baffle on my 75's tank that just went around the sending unit float. Mine was broken loose and just bouncing around. I tack welded it back into place when I took the bladder out. I assume it's there to keep the sending unit float from getting knocked around. It's so small I'm not sure whether or not you'd consider it a true baffle.
Old Oct 23, 2006 | 11:04 AM
beachbumtroy
Default gas tank
sorry guys thats what i meant was the bladder i just called it a baffle,what is it for? and apparently i can take it out,but what was it for to begin with? thnx again bb
To help with 75 coupe
