UV leak detection system?
Old Oct 24, 2006 | 07:55 PM
greyghost79's Avatar
greyghost79
Default UV leak detection system?
made a rare appearance at an Autozone today. saw a "UV leak detection system" on a shelf there. consisted of UV flashlight, goggles and UV dye. didn't get to read the particulars. what are these used for. engine, gasket leaks?? or A/C leaks? how do they work. anybody use them or like them?
Old Oct 24, 2006 | 09:40 PM
mkflanagan's Avatar
mkflanagan
Used for a/c leaks.They work great if you have a way to put the dye in the system.The one I have in my shop is a high dollar unit so i'm not sure about the autozone one.
Old Oct 24, 2006 | 09:49 PM
big_G's Avatar
big_G
I had a high-dollar one in my shop, the AutoZone unit beats it hands down. You can get dye for any liquid system (oil, trans., p.s., a/c, cooant). It is a great time saver, takes all the guess-work out of leak detection. Kind of fun,too.
Old Oct 24, 2006 | 09:52 PM
greyghost79
can you use it to find manifold/gasket leaks? where do you put the dye?
Old Oct 24, 2006 | 10:03 PM
682XLR8's Avatar
682XLR8
Get the dye specifically made for oil leaks, it should be in the same section. Put half the bottle in the engine and run it for 10-15 min, then check with the UV and glasses. You can use it for transmission leaks also
Old Oct 24, 2006 | 10:15 PM
greyghost79
will i need to change the oil after i do this? or can the dye stay in indefinitely?
Old Oct 24, 2006 | 10:18 PM
Topless75's Avatar
Topless75
The dye won't harm anything. Works beautifully. I have the AutoZone kit as well. Different vials for different fluids (antifreeze, transmision/crankcase, A/C).
Old Oct 24, 2006 | 11:57 PM
682XLR8's Avatar
682XLR8
Oil can stay, no need to change it afterwards
To UV leak detection system?
