Have you ever done a "Bubba" mod?
ESU
ESU
).We had spent all but $20 which we saved for gas for the ride home.Got the old bug up on 75 and headed north, set the cruise control(brick on the gas pedal)and 15 miles later the fuel pump went out.$hit
Not a problem,pulled out the glove compartment and stuck the fuel tank vent hose through and blew air into the tank and pinched off the hose and headed for home.Clever-Huh? When I got home (and still broke) I hooked my bike tire pump up to the hose.Clever? Drove the car that way for almost a year.
BUBBA ? Yep !!! True Story
ESU
and my wife keeps telling me "you complain about your son?"ESU
That is some quick whit. Thats the funniest thing I have read all day!!!!
Judging from the picture, it looks like I need to fix my temp gauge as well. (Don't worry, the car was off when I took the pictures, the gauges don't really read that when it is running)
Two tales (both true)
Tale 1. My lil' bro had a very built 70' Mach 1. He had traded the shaker hood for a detroit locker rear end, so was running it hoodless till he found another one. The throttle cable broke one morning on the way to work, so he removed both laces off've his tennis shoes and tied them to the throttle, bringing it in through the drivers window. It worked fine, till it stuck WFO approaching an intersection and he ended up having to think of something and killing the ignition at the last second.
Tale 2. The Caddy nobody owned. Four of us young Marines in the late 70's traded a pretty beat-up 64' gold Caddy between us. This saved us the trouble of having to get insurance and a base sticker every time we went through the main gate at Camp Pendeleton. The line was "I just brought the car yesterday". We got on base for many weeks before the Military Police wised up.
It ended up with a late night search of the vehicle, when my bud JJ got pulled over by the barracks with the flashing blues and reds. The MP's demanded a search of the car from front to back and asked him to open the hood. The Penn state boy, reached behind the seat and took out a baseball bat! The MP's were surprised, but he quickly explained that's how you held the hood open, which he complied with. Then they wanted in the trunk. He reached behind the seat and pulled out a large butcher knife. The MP's had the 45's out, ready to shoot him. We watched from the barracks and heard him exclaim, "Hell, guys, that's how I get the trunk open!" He walked around and stuck the knife in the trunk keyhole and popped it open. We roared in laughter to the dismay of the MP's. They didn't find nuthin', (but then again, we lucked out)
[centerforce D F, i didnt change piviot ball ]
yes- that's a nail instead of a cotter pin.
Road repairs on my old Harleys were often interesting, from as simple as channel locks zip-tied on the frame to keep the swingarm pivot nut tight when the lock-tab washer broke in SoCal, or rebuilding a clutch hub in South Dakota using peanut butter to hold the 52 roller bearings in the cage, or 2x4s bungee corded between the swingarm and frame when the air shocks blew out in Utah.
My best one though was when I had a valve stick and bent the stem 25 miles past Nowhere, Nebraska. Got the head off and disassembled and rode my girlfriends Sportster back to town where the only open shop was the Briggs & Stratton agency. The man laughed at me and invited me in back where we put the valve in a vice and hit it with a hammer till it was close. He then chucked it up in his small engine valve grinder and cut a concentric seat on it. I headed back to reassemble it and realized I had no valve grinding compound and it was too late to go back and get some, if I could even find any. I took sand and ground it it up real fine between two rocks and mixed it with toothpaste. Spun the valve with a piece of rubber oil line. Worked it down to just toothpaste for the final grinding. Using two tire irons baling wired together and a 10" crescent wrench as a spring compressor, I got the keepers set.
That bike ran for thousands of miles over the next couple years with that valve in it. Good bike.
Hauling three Harley Big Twins from SoCal to Colorado in my '59 Apache 3600 truck in August one year, I started vapor locking. I had installed a windshield squirter form a Pinto in the truck, so I wrapped a bandana around the fuel pipe and stuck the squirter hoses in the ends. Every few minutes I gave it a squirt....No more vapor lock.
On my car right now, I have two things I'm "prototyping": An air dam on the front which is 5" deep and about 58" wide made from an EPDM (rubber) roof membrane reinforcement pad, and a center grill to fill the hole where my front plate used to be made from an air conditioner condenser grill. I'm not satisfied with the grill, so I think I'll try some wire mesh typically used as stucco underlayment, painted flat black, across the whole front. Let the blinkers shine through it. If that looks acceptable, I'll probably make a permanent grill screen from stainless woven wire mesh.
Carry on, keep 'em rolling.
John
