original engine ?
Old Oct 26, 2006 | 09:09 AM
cjrps's Avatar
cjrps
1st Gear
Default original engine ?
I have a 73 (350 engine 51K) and the numbers on the block are 3970010 and the engine stamp numbers read V03014CLA. I don't see any #'s below the stamp # at all. Shouldn't there be another set of #'s below the stamp # to match my VIN # (1Z37J3S418122). How can I tell where this engine came from or if it is the original engine for the car?
Old Oct 26, 2006 | 09:39 AM
72LS1Vette's Avatar
72LS1Vette
If the pad doesn't have the last 6 numbers of the VIN stamped into it it isn't the original engine.
Rick B.
Old Oct 26, 2006 | 09:50 AM
wfo76's Avatar
wfo76
Yes, there should be a VIN stamp on the pad.
3970010 is the correct block casting number.
CLA is the suffix for an L48 automatic, do you have an auto?
0314 is March 14 engine assembly.
16,301 was the last car built in Feb 73.
19,253 was the last car built in March.
So yours was built probably 3rd week of March, so the 0314 is good.
I guess it's possible although I would think unlikely that STL forgot to stamp the pad or another possibilty is that the engine was rebuilt and decked and they only stamped the larger characters.
A pic of the pad would help.
Old Oct 26, 2006 | 10:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There should be two numbers stamped on the engine pad. You've found the engine number. VIN derivative should also be there (smaller characters than the engine number). Take another look.
To original engine ?
