69 Help!
Old Oct 28, 2006 | 12:31 PM
pj_kerr's Avatar
pj_kerr
Default 69 Help!
I'm replacing the 5 port windshield washer hoses, and the electrical leads associated. Can anyone post a picture/ diagram or explain how the washer hoses are routed to the various ports, on the washer pump and the anti drip solenoid.
Also how the washer pump and anti drip solenoid is wired into the W/S Washer harness? I have the lectric limited harness adapter that has the brown plastic connector with two black leads with brass terminal extensions on one end. Just trying to figure out how to connect. Trying to find pictures of the set up in this tight space is tough!
Thanks!!
Old Oct 28, 2006 | 06:22 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Does this help? The hose routing is in the AIM. Chuck
Old Oct 29, 2006 | 10:23 AM
pj_kerr's Avatar
pj_kerr
Chuck,
Thanks for the picture! this will help a bunch in the wiring department.
I've been studying the AIM, but with you're help, found the washer pump detail specifics on the a/C vacuum hoses page (where else!)
Appreciate the support. On the way to the garage!
PJ
Old Jan 4, 2014 | 12:48 PM
MarkHarclerode's Avatar
MarkHarclerode
Default Clip for Anti-Drip Valve..
I recently purchased a correct 1969 Windshield wiper motor with the Headlight washer solenoid. I also purchased the barrel connectors that connect the leads from the solenoid to the Windshield wiper motor! From your picture, I can see a plastic electrical connector that fits around the Nozzle from the solenoid and connects the wiring harness to the solenoid!
Do you know if anyone sells this electrical connector? Email mharclerode@cfl.rr.com... Thanks
Old Jan 4, 2014 | 03:45 PM
Chuck Gongloff
Wow, this is a moldy oldie..........2006 vintage.
As the old radio DJ's used to say....
"It's a golden nugget, because you dug it".
IIRC, there are only 2 wires to the solenoid, and those are the 2 depicted in the diagram.
Which "letter" area are your referring to?
Chuck
Old Jan 6, 2014 | 01:15 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
LOL......I have found several "antique" threads that have helped me out on my rookie project!!
To 69 Help!
