numbers check on C3
Old Oct 29, 2006 | 09:44 PM
fuelie65's Avatar
fuelie65
Default numbers check on C3
I just purchased a 72 coupe and I'm trying to check the originality..
I know you guys/gals on this site are the experts..
Can anyone help me authenticating these dates/codes ?
engine pad VO4950CKX I believe to be April 5th 72
Trim tag date is I 13
heads are C-29 and C-27-2 ( 3973487X ) whats's with the X ?
Block cast date looks like B 202
Old Oct 29, 2006 | 10:20 PM
alaskacorvette's Avatar
alaskacorvette
Default numbers
From what I know, you're OK. Your block stamp on the pad is for the base 350/200 horsepower(the 3 letter code). The trim tag is April (I) and the day of the month. 487X is the correct casting number for the heads. The block casting number on the drivers side, behind the cylinder head should be 3970014 but could be 3970010. Does any of the block stamp match the VIN? Have fun! Jim.
Old Oct 29, 2006 | 10:27 PM
fuelie65's Avatar
fuelie65
Thanks...yes the vin #'s match...does the B on the cast date de-code to February ? making the engine cast in February, engine pad stamped on April 5th and car completed April 13th ??
Old Oct 29, 2006 | 10:28 PM
fuelie65's Avatar
fuelie65
and yes the block casting is 3970010
Old Oct 30, 2006 | 12:04 AM
Tom73's Avatar
Tom73
The engine pad VO4950CKX has one too many numbers.
V=Flint Engine plant
CKX=base Vette engine for '72
but the 04950 has one too many numbers. Should be two digits for the month and two digits for the year. Something like 0405 for April 5th.
tom...
Old Oct 30, 2006 | 06:46 AM
fuelie65's Avatar
fuelie65
Default numbers
Tom,
Thanks the pad does read VO405CKX
Old Oct 30, 2006 | 12:09 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by fuelie65
...the pad does read VO405CKX
That's better. Flint, April 5th. 350CID, 200 hp, AT.
To numbers check on C3
