69 power window alignment
Old Oct 30, 2006 | 06:58 PM
Emmett's Avatar
Emmett
Default 69 power window alignment
I've noticed thst my passenger side power window comes out of alignment after closing the door.You can move it forward by hand but it will not stay in place.The entire window can be moved by hand about half an inch front to rear.What gives?
Old Oct 30, 2006 | 07:29 PM
rotgirl's Avatar
rotgirl
Default Window
You have about 6 different adjustments for windows.
There are adjusting bolts for:
1) Windows being tilted
2) Rolling up too far
3) Correcting the gap between the window forward edge anad the pillar
4) Glass being too far outboard or inboard
5) Window going down too far
6) And window being outside blow out clip when door is closed.
If you need detailed instructions, I can scan and email them to you.
rg
Old Oct 31, 2006 | 08:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Current issue of Corvette Enthusiast magazine has a photo how-to on door glass alignment. Good reading.
Old Oct 31, 2006 | 08:20 AM
jdp6000's Avatar
jdp6000
Best instructions I've seen...
http://www.71corvette.com/cn-apr/24.jpg
Jim
Old Oct 31, 2006 | 08:47 AM
moosie982's Avatar
moosie982
It still is a pain in the azz job to get right no matter how many procedures you try,,,Peace,,, Moosie
Old Oct 31, 2006 | 09:15 AM
75 Red Vert's Avatar
75 Red Vert
rg
I'd sure appreciate a copy of that rastrube A swbell.net
Old Oct 31, 2006 | 07:38 PM
rotgirl's Avatar
rotgirl
Default Windows
Let me know if you didn't get the email...rastrube A swbell.net
rg
Old Oct 31, 2006 | 07:54 PM
Edzred72's Avatar
Edzred72
Yep...this is what it looks like in there.
Eddie
Old Oct 31, 2006 | 08:29 PM
Emmett's Avatar
Emmett
Sure would like a copy of those instructions rotgirl.
Thanks, ljweaver@zoominternet.net
Emmett:
Old Nov 1, 2006 | 03:02 AM
Miq69's Avatar
Miq69
3rd Gear
rg
Would you please send one copy also to me, thanks
Old Nov 1, 2006 | 08:49 AM
75 Red Vert
rg
Thanks alot - got it. Pretty easy to follow. Now for the time to get the door panel off and get to work. I'll post results and pics.
Old Nov 3, 2006 | 10:39 AM
Emmett's Avatar
Emmett
Still looking for my copy,please.
Old Nov 3, 2006 | 11:00 AM
NHvette's Avatar
NHvette
Glass adjustment is in AIM and all the cheap manuals (Haynes,Chiltons).
I would be suspicious of it moving front-back after being raised fully.
It could be a loose adjustment bolt, or it could be a broken roller.
It might be worthwhile to study the picture that Edzred72 put up.
Inspect the rollers before doing all the adjustments. In his pic, there
is a big roller in the left vertical track - bolted to glass, a roller/slider
that links the right vertical track and the long horizontal track.
On the regulator, there are 3 small rollers - two in the long track
and one in the short track. These rollers should all fit tightly in the
tracks with no wiggle. Also, check the bolts that hold regulator to door.
Old Nov 5, 2006 | 10:26 AM
Emmett's Avatar
Emmett
Thanks,NHvette I will give her a try this winter.
Emmett
Old Nov 5, 2006 | 10:35 PM
Sayfoo's Avatar
Sayfoo
Just noticed in the picture that the ground wire is tek screwed or bolted to the doors metal frame. On my '69 the ground wire goes directly to the motor. Kind of hard to see the connection point unless you get down low to look at the motor. Its towards the geared shaft, on the bottom.
Old Nov 5, 2006 | 10:51 PM
whoodiestyle's Avatar
whoodiestyle
rg
can u send me a copy also bigdaddy239@hotmail.com
Old Nov 25, 2006 | 07:57 PM
Jerky_san's Avatar
Jerky_san
Can you also send the instructions to me as well jerky_san@hotmail.com
Old Nov 26, 2006 | 11:30 AM
kdzdds's Avatar
kdzdds
Finalist 2022 C1 of the Year - Unmodified
One more guy... I would appreciate a copy to hmartin1@kc.rr.com
Thanks...
To 69 power window alignment
