Interior cleaning tips
Old Nov 5, 2006 | 04:47 PM
crazywelder's Avatar
crazywelder
Originally Posted by dixie vette
Does anyone have any suggestions on cleaning seatbelts? Thanks in advance!
Seat belts can get a combination of dirt and grease embedded between the fibers and you can use stronger cleaners on them without destroying the fabric. Fantastik, 409, Simple Green and other water base cleaners work good at removing dirt and a toothbrush may be needed to get between the threads. To remove grease you'll need a solvent base cleaner such as Wax and Grease remover or other body prep solvent and Brake Clean works very good also (not the environmental safe stuff). But always test an area first to make sure the cleaners don't destroy the belt color because a previous owner may have dyed the belts.
