L82 manifold
Old Nov 4, 2006 | 04:00 PM
greyghost79's Avatar
greyghost79
Default L82 manifold
does the L82 (79) manifold have dual bolt patterns for either spread bore or square bore carbs. someone told me it does. haven't pulled carb yet and would like to know in advance. thanks for any info.
also, if i switch from Q-Jet to edelbrock performer or Holley carb what adapter, parts, etc. will i need in order to connect my stock 79 throttle linkage (auto trans and cruise)? thanks.
Old Nov 4, 2006 | 04:57 PM
Paul L's Avatar
Paul L
No, it does not. It was designed for a spread-bore Q-Jet.
Can't help with the other questions.
Old Nov 4, 2006 | 05:27 PM
Duke94's Avatar
Duke94
Buy the Edelbrock manifold to go with the Performer carb.
Old Nov 4, 2006 | 05:45 PM
greyghost79
what about just using their adapter plate?
Old Nov 4, 2006 | 06:08 PM
dgruenke's Avatar
dgruenke
You might run into hood clearance problems with the adaptor plate.
Old Nov 4, 2006 | 09:55 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
adapter plates suck...imho...What's wrong with your Q-Jet that you want to change carbs?
Old Nov 5, 2006 | 08:45 AM
Duke94's Avatar
Duke94
I agree, I had a Edelbrok for a while then had my Q-jet restored. Works much better and seems to have more power.
Old Nov 5, 2006 | 08:59 AM
Ganey's Avatar
Ganey
An adapter should not be used even if you had clearance which you don't.
To L82 manifold
