1981 Engine question....
Old Nov 4, 2006 | 08:22 PM
Richard Cooper's Avatar
Richard Cooper
Default 1981 Engine question....
Anyone here put a "Universal Crate Motor" in their 81? I am going to buy this motor , but I am NOT going to use the computer anymore. can you tell me what carb and distributor I would need for this? I talked with Summit but they can't tell me anything because of the Clean Air Act of 1991. Thanks for any help.
Old Nov 4, 2006 | 08:27 PM
3rd_Vette's Avatar
3rd_Vette
GM 350/260 hp crate $1450.
Edelbrock 1406 Carb $ 250.
Edelbrock 2701 Intake $125
GMPP HEI Dist $179 or a cheap Jegs dist for $89
With that and a new 2 1/2 exhaust, you should be somewhere near 300 hp. A far cry from the 180 or 190 stock HP motor. If you have the smog natzi's in your home town, you will need the Edelbrock EGR carb and manifold.
Hope this helps..
Old Nov 4, 2006 | 08:50 PM
3rd_Vette's Avatar
3rd_Vette
Default Out with the stock, In with the new.
Ir runs like a raped ape!
Old Nov 4, 2006 | 09:01 PM
Mark G's Avatar
Mark G
I can understand ditching the computer controlled carb, but no way would I go back to a regular carb unless I absolutely had to. Doing this upgrade, you are in the perfect position to perform a throttle body coversion. Have you considered that? Cost-wise, it might be as cheap or cheaper than a carb, potentially give you more power, definitely better throttle response, better idle, meet emissions and so on. Even retains stock look with air cleaner on.
There are a number of guys doing low dollar conversion using early 90's truck T/B systems from a boneyard. Corvette Fever did a feature on it this past summer. I scanned the article. I can send it to you if you are interested (send P/M). But it's definitely something to consider. I have an 81. I'm half tempted to do it.
Mark G
Old Nov 5, 2006 | 03:31 AM
Kalway's Avatar
Kalway
Before you outright decide to ditch the puter you should really consider keeping it. If you do it correctly, it'll actually run very well with the CCC. If you're not going for a huge performer, stick with the CCC system, you'll thank yourself in the end.
Old Nov 5, 2006 | 12:24 PM
Rich N.'s Avatar
Rich N.
Rich, when I bought my ' 81 4 spd, it had a new ZZ4 with CA pollution equipment. I changed it to a PA classic car registration, so I could get the most out of the engine. after taking off the smogg stuff (computer still on), a friend tuned (& rebuilt Lars specs)the q-jet and dist. the performance gain was dramatic. I have since installed a Demon and MSD. the ZZ4 has a lot more going for it than your engine and I felt the new carb and dist could get more out of my engine. it has. however, if I had your crate motor, I would stick with the original CCC carb/dist setup. I've had several 'vettes with q-jets and they're not bad carbs. there is money saved to consider also. good luck. Rich N.
Old Nov 5, 2006 | 04:03 PM
Richard Cooper
Thank you all very much. I am for sure going to ditch the computer. I have had enough trouble with the computer over the last 4 years that I don't care what it takes, its gone.
I just found out that my daughter (who is in 2nd year of college) has been accepted into a travel program and is going to Rome the day after Christmas for 16 days. So, there goes my motor AGAIN! Maybe by the time I get this motor I will feel different about the computer. Thanks again.
Old Nov 5, 2006 | 04:08 PM
Kalway's Avatar
Kalway
It'd be more cost effective to go with a standard vacuum advance HEI and a 4MV q-jet with your new engine than anything else.
To 1981 Engine question....
