Motor Mounts > suggestions ?
Old Nov 5, 2006 | 10:38 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Motor Mounts > suggestions ?
While I have the tie rods dropped for the oil pan replacement, I figured I would also replace the original (dried out) motor mounts.
This is for the wife's 74 454.
Any suggestions on brand > standard autozone ? others ?
Thanks....
Old Nov 5, 2006 | 10:45 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
make sure you get the interlocking type. If rubber fails it will only move so far.
take a look at them before you buy.
Old Nov 5, 2006 | 01:27 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
GM still has motor mounts in stock at your dealer's parts counter.
To Motor Mounts > suggestions ?
