I thought I had done a post on this subject.....must be getting old. What should I expect to pay for a hardtop for my 70' roadster. Must be complete, no garbage. Car has black interior. Does one need to do anything to the car to attach the hardtop? special fittings? drilled holes? etc. Regards, Mike in San Diego.
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Hard Tops
Seen prices for hard tops ranging from $500 area for fair ones, $1500 area for mint ones, in most cases you will need a repaint to make it match, unless it's a vynal top. As long as it's a convertible no alterations are needed at all.... ... .....just be carefull putting it on & taking it off so you dont scratch anything, it's heavy & awkward to handle .
with the exception of door glass weatherstripping and possible door glass adjustment.
If you get the hardtop, mount the hardtop on the car. Adjust the door glasses to the weatherstripping on the hardtop to get a good fit. Hopefully, you will be able to get a good seal without having to adjust the door glasses themselves. If not, you will have to adjust the glasses at this point because the weatherstipping on the hardtop is not adjustable.
Remove the hardtop and raise the folding top. Adjust the weatherstripping on the folding top to the door glasses. Do not change the position of the door glasses or you will negate the fit you got with the hardtop on.
Just my .02, but I'd stay with the OEM top. You know it's going to fit and not give you any surprises.
It's not my intention to give a bad rep to the Smoothline folks. I am not familiar with their product. For all anyone knows, they made have made the originals for GM.
Funny.........
FUNNY ............your right, you never know who made what for GM ZIXXX PACKER
If you look long and hard and get lucky you can find a decent top for $500. The real trick is to find one close enough to you that you can pick up. Crating and shipping a hardtop is tricky and expensive - can easily add $200 or more to the cost of the hardtop.
If your convertible did not come from the factory with a hardtop then it will not have the additional attaching points that you will want, but maybe don't absolutely 100% need. These additional attaching points are a third hole in the middle of the rear decklid, and 2 holes directly behind the doors. pics coming.............
See dat little hole in der? A bolt goes through a tab on the hardtop and into that hole to help hold the hardtop securely on to the car.
I just spoke with the guys over at Smoothline. They were pleasant to talk with and he answered all my questions, etc. In short, the top is about 45lbs. From what I remember of my hardtop this is about 1/2 the weight of the original and maybe even less. Anybody know how much the original hardtop weighs all trimmed out, etc? There was a vette show in California that had the their hardtop installed and it took 1st place. I have no idea what the other competition was at the show. Well…after I get all my mods done (hopefully by this time next year) I can justify purchasing this hardtop as I really only need it for racing purposes down the 1/4 mile dragway as I don't want to add 200lbs and then watch my 1/4 ET's drop 0.1 secs. Price was about $1,200 right now as they are running a special from the usual price of $1,500. Sounds like a good alternative if you are looking for something a little different vs. original.
Hey - thanks for the info about Smoothline. $1,200 for a new top isn't too far from prices for good originals. I may have to look into this option further...
First pic is the center latching pin hole in the center of the rear deck.
This is a pic of the side bolt which secures the hardtop.
My black vinyl hardtop......probably going up for sale in the spring.
Whatever you do, make sure you get that clear plastic stuff that goes between the hardtop and your paint. Saves the paint from the top. I think it is called a decklid protector or something like that. Most of the vendors carry it.
