Alloy Wheels
Old Nov 10, 2006 | 11:58 PM
ksbunting's Avatar
ksbunting
Default Alloy Wheels
How hard is it to restore alloy wheels?
What is involved and can it be done by a do it yourselfer or must they be sent to a professional?
No specific wheel in mind, just a generic question.
Thanks,
Kurt
Old Nov 11, 2006 | 10:17 AM
moosie982's Avatar
moosie982
It depends on the actual condition of the wheel, rough cast, smooth cast, polished, clear coated,? The work involved is tedious,, not hard physically but very labor intensive. Any clear or any coating needs to be removed by whatever means you choose, then "polishing" by progressively finer and finer abrasive (sandpaper?) until its as smooth as a babies butt and finally a good polishing, try a google search for "ZOOPS", see what ya learn from them,,,,,Peace,,,Moosie
try this link: http://www.zoops.com/zoopseal.asp
Old Nov 11, 2006 | 05:13 PM
ksbunting's Avatar
ksbunting
Thanks Moosie.
Old Nov 11, 2006 | 10:30 PM
19vette80's Avatar
19vette80
If you use paint stripper it will take the clear coat off then if there just small pits start with 320 wet or dry then go to 600 wet or dry wet sand then use major cut rubbing compond and work your way to mothers wheel wax
Old Nov 11, 2006 | 10:34 PM
ksbunting's Avatar
ksbunting
Jim,
Will this work for pitts and minor corrosion?
It is a friend's BMW wheel with clear coat finish.
Kurt
Old Nov 11, 2006 | 10:38 PM
19vette80's Avatar
19vette80
Kurt isThe corrosion is a black color yes it will work is takes some work but if its not to deep they will clean up nice!An electric buffer with some power helps alot.
Old Nov 11, 2006 | 10:39 PM
80_vette's Avatar
80_vette
I've redone mine last winter and the Mother's powerball worked awesome
Of course mine were just oxidized.A good scrub got 'em to a mirror shine
Old Nov 11, 2006 | 10:51 PM
19vette80's Avatar
19vette80
Does the powerball work as good as they say!
Old Nov 12, 2006 | 01:36 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If it's black, it's likely not corrosion - it's brake dust. Get some good wheel cleaner to get rid of that.
Old Nov 12, 2006 | 10:21 AM
80_vette's Avatar
80_vette
Oh yeah!I'm a big fan of the Mother's powerball.I've done 'em once by hand and it's so agonizing to the fingers...
If you do get the powerball,get the mini,easier to get in small cracks..Takes me about 10 minutes each wheel.By hand it takes me over an hour and my hand hurts like hell after.
Old Nov 12, 2006 | 11:29 AM
ksbunting's Avatar
ksbunting
It is black corrosion and it has eaten slightly into the wheel.
When I tried to clean it off, it leaves a black spot which is noticeable since the rest of the wheel is silver in color with a clear coat over it.
I am concerned that I will do more harm than good but realize that there are companies out there who restore wheels so I am wondering How they do it so I can duplicate the process.
Kurt
Old Nov 12, 2006 | 09:29 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
only if the wheels are in good shape to begin with.....it will maintain a nicely cleaned wheel pretty well.....it will not restore a badly oxidized wheel.......i used a die grinder, stone wheel, buffing pad, 320 soft pad 220 and 100 sand paper and went to town this weekend on some road rash on my wheels.......turned out to be a surprisingly good job, took some time but the road rash is gone...........
To Alloy Wheels
