Claying Question
Old Nov 11, 2006 | 04:55 PM
ksbunting's Avatar
ksbunting
Default Claying Question
Does using a clay bar on the paint do any damage if done to often?
In other words, would it hurt to clay the car every time you wash it?
Does it remove any wax that is on the finish?
I am using Zaino Z-18 clay and clayed the Corvette today and I really like the smooth finish it leaves but I also don't want to overdo it.
May be a silly question, but thanks for any input or insights.
I never used clay before until today AND I LIKE THE RESULTS.
Kurt
Old Nov 11, 2006 | 05:19 PM
Sacredgrooves's Avatar
Sacredgrooves
it will remove every trace of wax from your car(and alot of contaminates).
I use it a few times a year....basically whenever I want to strip all the wax and do it again. if you use it all the time, you will of course have to re-wax your car all the time.
Old Nov 11, 2006 | 05:23 PM
ksbunting's Avatar
ksbunting
Thanks Dave.
While I have your attention, and since I can see the shine on your Corvette all the way here in Massachusetts, what do you use on the finish?
My car (68 Coupe) was freshly stripped and painted LeMans blue last year and I have only washed it 2 times as I wanted to let the paint cure. Have not waxed it yet but borrowed a neighbor's Porter Cable Random Orbital Buffer today.
Any suggestions?
Kurt
Old Nov 11, 2006 | 05:26 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
dont use a buffer unless you know what your doing. from what i hurt you could screw up your paint
Old Nov 11, 2006 | 05:27 PM
79 vette head
St. Jude Donor '10
heard
Old Nov 11, 2006 | 05:38 PM
72350auto's Avatar
72350auto
Is rubbing compound just another form of clay bar? Basically looks like mud(clay) and I think does the same thing?
Old Nov 11, 2006 | 05:44 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Originally Posted by ksbunting
Thanks Dave.
Any suggestions?
Kurt
Kurt, My 68 BB is LeMans Blue also. Great color. I claybarred the car when I bought it last winter as it felt like it had some overspray on the fresh paint. I then used Zaino Z6 then Z2 and finished with Z8. The stuff works fantastic. It really is unnecessary to clay bar often unless the surface is no longer smooth. You can use the "Baggie test". Rub a celophane baggie over the surface and see if it catches/snags. If it doesn't and feels smooth I wouldn't bother with the clay. I also wouldn't use the Porter Cable unless you are good with it.
If you ever get to the Cape look me up
Old Nov 11, 2006 | 05:55 PM
britvette's Avatar
britvette
Hi - thought I would live up to the newbee steriotype and ask the obvious stupid questions - Whats a clay bar , whats it for , do I need one and where can I get it .
I think that has them all covered
thanks
Old Nov 11, 2006 | 06:09 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
thanks
It appears like a wad of clay. It is rubbed over a well lubricated surface to take the contaminants out of the paint and properly prepare the surface for your favorite wax, polish or sealant. Mothers makes an over the counter clay bar kit that comes with the spray lubricant. You rub it lightly over the well lubricated paint surface and it lifts out the contaminants in the paint. It provides you with a smooth surface ready for your polish. It is great for taking things like paint overspray off the paint. If your finish isn't smooth it is a great candidate for a good clay barring. Just be careful not to apply too much pressure and keep the surface well lubricated so you don't damage the paint. Keep turning the clay bar over to the clean side and manipulate it. You will see the bar picking up debris off the paint.
You will get a better shine out of your paint by properly preparing the surface. Lots of discussion on this in the Car Care Section
Old Nov 11, 2006 | 07:06 PM
Sacredgrooves
Kurt,
I use the zaino line and apply it with a porter cable. when I first bought my PC, i was nervous, but I found the only way you can hurt the paint with a randon orbital is if you throw it at the car. now...I do try to stay away from the sharp edges and do those by hand, but I have yet to do any damage. pc's can do a much better job than by hand....and much faster lol. there are different styles of pads too...orange for cutting to remove swirls and such, black for wax and finishing work etc...
someone asked about rubbing compound...that is different than clay bar. it is an abrasive used to remove swirls and light scratching. I would recommend against rubbing compound found in the local stores on a nice finish and use something like menzerna intensive polish followed with menzerna final polish II or zaino fusion to remove depper blemishes. with mine being black, I err on the side of caution though.
Old Nov 11, 2006 | 07:15 PM
britvette's Avatar
britvette
Thanks for the explanation , is it ok for use on clear coat or just on single part paints?
Old Nov 11, 2006 | 07:26 PM
Sacredgrooves
it claims it is safe on any paint surface. the key is keep the surface lubricated well. I do 2'x2' sections keeping the paint wet with a spray bottle filled with water and some zaino car wash solution. it should glide smoothly over the paint and you apply virtually no pressure....just let it slowly glide across the surface. kneed and shape the claybar every so often to keep a clean contact surface.
garage-ghost's Avatar
garage-ghost
No rubbing compound is NOT like clay bar. Rubbing compound is an abrasive and clay is not. Clay will not take out scratches like rubbing compound. It just removes contaminates.
Old Nov 11, 2006 | 08:19 PM
rihwoods's Avatar
rihwoods
I use a mild clay bar...
Old Nov 11, 2006 | 08:55 PM
ksbunting's Avatar
ksbunting
Capevettes,
I have long admired your collection of toys.
Very nice,
Kurt
Old Nov 11, 2006 | 09:03 PM
ksbunting's Avatar
ksbunting
Dave,
I am out here in the garage this very moment giving my baby its first wax job since the restoration was finished. Using the Porter Cable and Meguiar's Carnauba Wax (liquid) since that is all I have.
I am going to get the Zaino line as I have heard so much about it. Just wanted to get something on it tonight since the paint was clayed this afternoon and is now "exposed" to the elements. It only leaves the garage when I take my little rides but this Porter Cable thing is AWESOME. I must get one of these for myself. No swirls, just paint smooth as silk.
Happy, Happy Happy
Kurt
Old Nov 11, 2006 | 09:19 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
[QUOTE=Sacredgrooves]..........and apply it with a porter cable. when I first bought my PC, i was nervous, but I found the only way you can hurt the paint with a randon orbital is if you throw it at the car......
:QUOTE]
i agree the Porter cable is a really nice machine...very user friendly
Old Nov 12, 2006 | 10:30 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
Capevettes,
Very nice,
Kurt
Thanks Kurt. After retiring, fleet maintenance became my new occupation
Old Nov 12, 2006 | 11:22 AM
ksbunting's Avatar
ksbunting
Paul,
Tough job but someone has to do it.
Actually, to me that is a wonderful way to spend retirement.
A few more years and I will be there.
Unfortunately the aches and pains in the aging body prevent doing as much as I once did especially in the confines of a C-3, like under the dash or in the rear storage compartment. Just can't twist like a pretzel any more.
Kurt
To Claying Question
