St. Jude Donor '03-'05-'06-'07-'09
Oil Pan Drain Plug Question???
On a SB, where is is the oil drain plug located? On the drivers side? Or centered in the backside (facing the rear od the car) ? That's where the plug is for this 72. And the plug is bigger than what I remember for sbc's!!!
Mark
I've never owned a big block, but of the two 70's and 71 that I've owned all of the drain plugs were centered on the back of the oil pan. I think that is where it should be located on stock oil pans for early sharks.
Originally Posted by mkflanagan
It's gonna be the bolt on the BOTTOM of the oil pan.
Yeah, yeah, yeah...thanks...
On a side note put a FWD car on the rack, 2 pans side by side, cast aluminum and the average guy would problably drain the tranny!!
Thanks to all who replied. I was trying to determine if my oil pan was original. Couldn't find and pics of the Vette pans.....looks like the pan is original.
