74-75 rear deck vent grills
Old Nov 16, 2006 | 08:34 AM
Patrick73's Avatar
Patrick73
Default 74-75 rear deck vent grills
All 74-75 coupes had rear deck vent grills installed behind the rear window. Do 74-75 coupes with air conditioning have plates installed bocking off the grill openings?
I think coupes without air conditoning do not have block off plates installed.
Old Nov 16, 2006 | 09:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For that matter, all 68-75s had the deck vents. For AC cars, on some model years, the vents inside the car are supposed to open and exhaust interior air out through the vents as part of th Astro-Ventilation system. With the AC on cool, the inside doors are suppose to close.
Old Nov 16, 2006 | 10:13 AM
Patrick73's Avatar
Patrick73
Mike, You are correct regarding 68-75 cars, but I think (not 100% sure) all 74-75 coupes w/air cond had actual block off plates (painted flat black) installed directly under the rear deck vent grills. In other words, the rear vents were completely non functional on 74-75 year coupes with AC.
Old Nov 16, 2006 | 10:17 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
Does anybodys vents have water drains in them and would it be hard to Put them in ? Its A pain wash and dry go for A ride Runs over the back deck .
Old Nov 16, 2006 | 10:35 AM
Patrick73's Avatar
Patrick73
Lon, Your car should have two rubber vent drain hoses. One on each side; one for each grill. Look in the area behind your seats. You should see the two rubber drain hoses. They exit into the top rear fender well. See corvette central Part No. 333060 for a photo.
Old Nov 16, 2006 | 12:11 PM
The Spark's Avatar
The Spark
My 72 convertible a/c car has blockoff plates in the Astro ventilation ducts in the back of the baggage area. It is original.
There is nothing under the vent grills on the decklid.
Old Nov 16, 2006 | 12:21 PM
Lon Wayne's Avatar
Lon Wayne
Default Hoping for holes
Nope no holes, no hoses ,no drain, No S?'t
Can you buy these little parts form somewhere I never really looked ?
Old Nov 16, 2006 | 12:22 PM
Bill Baird's Avatar
Bill Baird
The same was true of my 1975 coupe with air.
Old Nov 16, 2006 | 02:32 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...my '74 non A/C has the open vents, my "used to be A/C" 1975 has the block off plates.
Old Nov 16, 2006 | 04:31 PM
75BrownC3's Avatar
75BrownC3
If you have a leaf blower, use it to blow out the water and dry it.
Old Nov 16, 2006 | 04:57 PM
Orangevette's Avatar
Orangevette
Mine has block off plates, 1975 coupe with a/c.
Old Nov 16, 2006 | 05:03 PM
NHvette's Avatar
NHvette
It wouldn't take much to fit a small drain hose to the block off plates ...
but I've never done it.
I would use a screw-on tire valve stem, remove the valve core, remove
the "inner" rubber washer, cut a groove through the inner portion to
drain flush, and install in the recesses (drilled hole).
Mount with some RTV (on/around "outer" rubber gasket on interior side) to
prevent interior leaks. Then run a small rubber hose to the side (rear
inner fender), where another stem is mounted to exit into the wheel
well. Clamps on the hoses, obviously.
Done.
Stems:
http://www.jegs.com/images/photos/30...306-2900-4.jpg
Old Nov 16, 2006 | 08:15 PM
vettecrazy88's Avatar
vettecrazy88
75 A/C blocked off
Old Nov 16, 2006 | 08:27 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Done.
Stems:
can you add a page to the assembly manual showing a pictoral representation of how to do that?
Old Nov 16, 2006 | 09:55 PM
Bill Baird's Avatar
Bill Baird
I always just took a couple of towels that had fringe (or loose threads) on the end and plopped them on top of the vents (threads in the water). I then let them sit for a bit whilst I dried off the rest of the car, and by the time I was done, they had absorbed the water that had accumulated under the vents.
Old Nov 17, 2006 | 12:43 AM
LQQK's Avatar
LQQK
I have used a piece of brass tube from the local hobby store, flaired it and drilled a hole down in there and used a countersink so I could get the pipe low enough to get all the water out. Then used some silicone to seal it. and put some on the rubber hose so it won't slide off. I've also done this on trunks too that have a habit of not draining. Copper tube works too. Steel brake line rusts out.
Old Nov 17, 2006 | 09:49 AM
psw5940's Avatar
psw5940
My 75 coupe with A/C has vents blocked.
Old Nov 19, 2006 | 01:08 PM
75coupered's Avatar
75coupered
Default same
My 75 coupe with A/C no vents, cant even see block off plate just never cut open for vents, no drain either.
Old Nov 19, 2006 | 05:12 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Same for my 71 w/ac.
To 74-75 rear deck vent grills
