Panel adhesive ???
Old Nov 20, 2006 | 12:08 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default Panel adhesive ???
What's a good adhesive for body panels - I've been looking at 3M #8115 but can't find it locally.
This is for my flares, I guess I cannot just use the Bondo putty
Old Nov 20, 2006 | 12:15 AM
JonnHeather's Avatar
JonnHeather
I've used the 8115. Great product and a very good work time. You can buy it online at any of the autobody specialty stores...
Old Nov 20, 2006 | 12:37 AM
sperkins's Avatar
sperkins
I've heard that Fusor is the best. No idea where to get it though.
I googled it and found this:
http://www.lord.com/tabid/3401/Default.aspx
Old Nov 20, 2006 | 12:54 AM
MixxMaster's Avatar
MixxMaster
Evercoat's Vette Panel Adhesive!
Old Nov 20, 2006 | 01:00 AM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Dave
Old Nov 20, 2006 | 09:39 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
OK, i tried to get some product info on these adhesives. So far I found that the Evercoat Vette Panel adhesive is for bonding fiberglass only (found on Evercoat's website):
Vette Panel Adhesive/Filler™
A polyester body filler for fiberglass and SMC panels. No shrinkage. Helps prevent repair mapping on seam lines over fiberglass repairs. Used to bond fiberglass panels only, not SMC. Blue cream hardener included.
All the other adhesives from 3M (8115, Duramix) require a mixing gun, these sell for $80-$120
The only adhesive that is supposed to work on SMC AND comes in a qt container is this:
http://cgi.ebay.com/ebaymotors/Everc...spagenameZWD1V
any ideas ???
SMC Panel Adhesive
The only polyester adhesive strong enough to bond small SMC panels. Repairs small areas on SMC or fiberglass surfaces. May be reinforced with fiberglass mat or cloth. Has superior moisture resistance and lasting strength. Blue cream hardener included.
Old Nov 20, 2006 | 10:26 AM
big_G's Avatar
big_G
We use alot of the Evercoat 994. Good stuff.
Old Nov 20, 2006 | 11:37 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Order placed - hope to get this stuff before the weekend (probably not)
To Panel adhesive ???
