Rocker Panel Removal
Old Nov 20, 2006 | 06:11 PM
77vetter's Avatar
77vetter
Default Rocker Panel Removal
I want to take my rocker panels off to refinish them, but am having problems. I'm not much of a mechanic, so any advice will be appreciated. The screws are so tight I can't get them off. Do I need some kind of impact screwdriver or is there something else I can do to loosen them?
Old Nov 20, 2006 | 07:16 PM
Duke94's Avatar
Duke94
You can try spraying penatrating oil from the back side. After spraying a few times, lightly tap the end of the screw driver with a hammer to try and shock it loose (much like an impact screwdriver would do). Also use a GOOD phillips screw driver so you don't spoil the head.
Old Nov 20, 2006 | 07:52 PM
Vettkeeper's Avatar
Vettkeeper
I had to drill the heads off the screws to remove the trim. Zip Corvette sells a repair kit to replace the rocker trim. Part # BL-305.
Old Nov 20, 2006 | 08:56 PM
DO2G's Avatar
DO2G
Mine came off with some muscle and a screwdriver. I had mine powder coated and they came out awesome.
To Rocker Panel Removal
