Vent Balls!
Old Nov 20, 2006 | 09:05 PM
Fatty_VM's Avatar
Fatty_VM
Default Vent *****!
Just re-doing some of my interior, and was thinking about purchasing some VentBalls to replace my beat up ones.
Anychance you guys know how to take em out without removing the dash on a '76? Also, anybody have expiriance using http://www.riksvet.com/?
Old Nov 20, 2006 | 10:27 PM
roger55's Avatar
roger55
Rik's is good.
Vents must be removed from the rear.
Old Nov 20, 2006 | 11:03 PM
Muddywaters's Avatar
Muddywaters
Don't know about the 76..but on my 72...if you turn them sideways they pop out from the front... Muddy
Old Nov 20, 2006 | 11:18 PM
ksbunting's Avatar
ksbunting
Technically they should be removed from the rear side of the dash, however, on my 68 I can gently pry them out from the front. It is a tight fit but it can be done and it saves you from removing the dash.
Don't know if the 76 is the same.
If you try it, be gentle so you don't damage anything.
Kurt
Old Nov 20, 2006 | 11:56 PM
Fatty_VM's Avatar
Fatty_VM
Cool beans, thanks for the responses again guys!
Old Nov 21, 2006 | 01:12 AM
Love My 72 and 77's Avatar
Love My 72 and 77
That is the same exact name I have for a pair of jeans with the crotch torn out....wierd
Old Nov 21, 2006 | 07:54 AM
Hogwild's Avatar
Hogwild
very true i did mine from the front .
ntq
Old Nov 21, 2006 | 10:19 AM
69'Silver's Avatar
69'Silver
For those you need to swap the two words around
Old Nov 21, 2006 | 12:24 PM
Glassbowtie77's Avatar
Glassbowtie77
That's how I did mine.
Old Nov 21, 2006 | 01:34 PM
427-390's Avatar
427-390
This is good information. I have 2 new vent ***** for my '68 that I wanted to replace, and the thought of not having to contort my body in god knows how many ways to remove them from the back of the dash is good news.
Thanks.
Old Nov 21, 2006 | 07:49 PM
68AIR's Avatar
68AIR
Commando?
Old Nov 22, 2006 | 01:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
They come out (and go in, for that matter) from the rear. If you can get them out the front, the felt seals are worn and need to be replaced.
Old Nov 22, 2006 | 01:49 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I try to keep my ***** vented as much as possible.
Old Nov 22, 2006 | 05:46 PM
James.70's Avatar
James.70
From: Show me a cold beer and I will show you a happy man Maryland
cool beans jeans...they'll keep your ***** vented...has a catchy ring to it, think of all the markrting possabilities!
To Vent Balls!
