Cleaning Alternator
Old Nov 21, 2006 | 03:03 PM
DO2G's Avatar
DO2G
Default Cleaning Alternator
I plan on cleaning the outside of my alternator this weekend. Any tricks to making it look like new?
Old Nov 21, 2006 | 04:04 PM
Bill Z's Avatar
Bill Z
Avoid using any harsh chemicals like oven cleaner. It will turn the aluminum dark. Just use the parts store degreaser and a soft brush. Then rinse. After rinsing, let it dry real well before using. If real dirty, you can wash twice.
IWhen it comes as clean as you want, you can apply some high temp clear coat to keep it bright. Just a light coat.
Hope this helps.
Old Nov 21, 2006 | 04:09 PM
sfallison's Avatar
sfallison
I've used a combination of a wire brush attachment (on a drill) and one of those small wire brushes (toothbrush sized).
Old Nov 21, 2006 | 07:59 PM
GUSTO14's Avatar
GUSTO14
I usually buy a rebuild kit, front & rear bearings and set of brushes, then field strip the alternator and sandblast the two halves. Add a little clear-coat and bake at 200 degrees for 30 minutes or so. Reassemble and viola you have a new alternator that looks terrific and will last another 70 thousand miles...
Many of the vendors carry rebuild kits and if not, most good auto parts stores carry the pieces and they're not very expensive. Add the hi po (over sized) pulley and it will look even better. All for about the cost of a rebuilt alternator.
Good luck... GUSTO
Old Nov 21, 2006 | 09:05 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Got to Advane or Autozone and get a reman for $29.95...nice and bright...paint it clear ad you are good. Assuming its not the origianal piece for the car!
Old Nov 21, 2006 | 10:07 PM
roger55's Avatar
roger55
Options:
1. disassemble completely and bead blast it.
2. clean it and paint it with aluminum paint.
3. buy a new one.
Old Nov 21, 2006 | 10:15 PM
...Roger...'s Avatar
...Roger...
Spray aluminum wheel cleaner works good.(Not the clear coat type.)
To Cleaning Alternator
