74 Radiator Removal UUhhhh!
Old Nov 22, 2006 | 05:00 PM
hayman's Avatar
hayman
Default 74 Radiator Removal UUhhhh!
What’s the trick to getting the radiator out of a 74? I have the top brackets removed, better yet, EVERYTHING is loose and unbolted, including the core support. How do you get the shroud over the a-arms?
Bill
Old Nov 22, 2006 | 06:05 PM
redwingvette's Avatar
redwingvette
Pull the support toward the front of the car as far as you can and then pull the fan shroud up, left side first. It will take a little twisting but it will come, I have done mine several times. It is a Big PITA.
Old Nov 22, 2006 | 06:44 PM
gmg1977's Avatar
gmg1977
It helps if the shroud is broken just ripped it out the rest of the way.
Old Nov 22, 2006 | 07:29 PM
SmokinBBC's Avatar
SmokinBBC
Did you remove the hood?
Old Nov 22, 2006 | 08:51 PM
hayman's Avatar
hayman
No, is that what it is going to take?
Bill
Old Nov 22, 2006 | 11:19 PM
swensonm's Avatar
swensonm
Default Pain in the Azz
Bill
I just did my 74 last month ..What a PITA. I was able to pull the rad out from between the support and the shroud, then remove the shroud. Had to break the seals loose for the insulation (air dams). Passanger side A frame was a PITA. On the install no way I could do it with out removing the hood. I listened to members to tell me not to remove hood but a CF member came by to help out...as soon as we removed the hood the rad almost installed itself. Take to hood off.... it made install sooo much easier!
Old Nov 23, 2006 | 12:08 AM
Blue 74's Avatar
Blue 74
Replaced my radiator in August in my '74 and didn't have to remove the hood. In fact I didn't feel the hood was in the way at all.
The fan shroud is another matter all together. Like it has been said: a lot of twisting - but really no big deal. It was one case where force was called for. I think most of the problem was on the passenger side but twisting and pulling did the trick. I did take the time to remember how I twisted it to get it off and that remembering made it easier to get back on. Didn't even bend any radiator vanes.
Old Nov 23, 2006 | 06:12 AM
RS69's Avatar
RS69
Once you pull the hood, the job gets a lot easier. I had to pull the hood when I did my 74 and 69 BB.
Old Nov 23, 2006 | 07:42 AM
redwingvette
Pulling the hood does make it a lot easier. I don't know how you can pull the rad without pulling the shroud first, the lower rad hose is almost impossible to remove/install with the shroud in place. I put the rad in and attach the lower hose and then put the shroud back in.
Old Nov 23, 2006 | 08:53 AM
SmokinBBC's Avatar
SmokinBBC
Bill
I pulled the hood. Made the job a heck of a lot easier! I pulled the rad with the support. Cleaned and painted the support. I then installed the new radiator on the support with a new seal kit. Put it back in the car and installed the shroud before I tightened it all down. ( I have A/C as well).
Removing the hood is very easy. It is a 2 man job though. I had my 16yo son help with the whole process.
I hear everyone saying it is a PITA. I didn't think it was that bad. Everything came out and went in without a problem....but then again, if I had to do it without any help, it would have probably been a real PITA.
Old Nov 23, 2006 | 11:35 AM
vettecrazy88's Avatar
vettecrazy88
SmokinBBC, redwingvette, and others are all over this. It is soooooo much easier if you take the hood off. Mark bolt to hinge locations on the hood so reinstallation and alignment is easier. Lots of penetrating oil on all radiator support bolts. I twisted one of the welded nuts off the suppport on mine. The radiator, shroud and support come out as a unit. You can install the shroud seals while its out and reinstall as an assembly. That way the seals wont relocate on you as you are sliding the radiator in and out. Not to mention damaging the radiator fins if you slide the radiator in . I also believe it is a two man job unless you are very good with and overhead lift. Fought for a day and a half trying to get shroud in before removing hood and had it out then back in - 4 hours.
Many advise cutting shroud for ease of removal and installation. I can see how that would simplify things though. I had trouble convincing myself to do that with spankin new shroud.
I have a jar that I put $0.25 in every time I swear while working on the Vette. This job netted me around $10.00. Some went in a dollar at a time as I fit several into one sentence.
Good luck.
Old Nov 23, 2006 | 12:31 PM
SmokinBBC's Avatar
SmokinBBC
Good luck.
No need to cut the shroud, it will come out and go in with a little persuasion.
Like the quarter in the jar thing!
Old Nov 23, 2006 | 12:38 PM
corvetteload's Avatar
corvetteload
When I did my 75, thought I would put shroud in when everything was done------WRONG!!!!! I had to loosen support and push forward as far as possible and undo the top a-arms and swivel back toward firewall to get the shroud past them. It was a ROYAL PITA!!!!!!!!!!!!!!!!!!!!
Old Nov 23, 2006 | 03:16 PM
rihwoods's Avatar
rihwoods
Just finished installing an alum Dewitts in the 78 yesterday...did not remove shroud/hood...but I did take bolt & bushing washer off the pass
side A-arm,which allowed 1/2" more room dropping Rad in with no interference with lower rad outlet tube...I just moved the shroud back towards engine...
Pic taken just after I dropped rad in place..
Rich
To 74 Radiator Removal UUhhhh!
