Need new door key..
Old Nov 23, 2006 | 10:55 AM
RyanisBRUTAL's Avatar
RyanisBRUTAL
Cruising
Default Need new door key..
Previous owner lost the door key.. So what would be the cheapest way to go about getting one?
Old Nov 23, 2006 | 11:25 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Default Jessers
I HAVE USED JESSERS they specialize in old locks & keys & are always found at most major car events.
CLICK HERE >>>>>>> http://www.jessersclassickeys.com/
Old Nov 23, 2006 | 12:21 PM
MakoShark72's Avatar
MakoShark72
If you pull the lock from the door, a local locksmith can make you a key for you, probably for under $20.
Old Nov 23, 2006 | 12:55 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
A good locksmith can handle that with no trouble at all.
Old Nov 23, 2006 | 12:59 PM
andylmusic76's Avatar
andylmusic76
most of the corvette keys have a letter that is engraved in it, referring to the pattern of the key. if you can find this out then you can buy a new gm key from ecklers or wherever with that letter, then you're all set.
Old Nov 23, 2006 | 01:08 PM
MakoShark72
And to amplify a little.....
I had the door key to my sons 78 280Z, but the passenger door lock had been changed by PO, with no key....so we had one key for drivers door and hatch, another key for ignition, and NO key for passenger door. Looked around for lock sets, to match everything to one key, BUT they were around $200 for restored ones!!! So I pulled the drivers and pax door locks and hatch lock, ran them down to local locksmith, and had them all keyed to match the ignition key. Cost me about $45, now one key for the car!!!
I have seen Corvette lock sets for around $30??? Might be more cost effective to replace them as a set, then you have new, matching, unworn locks, even if not original to the car??
Rob
Old Nov 23, 2006 | 10:30 PM
427SIXPACK's Avatar
427SIXPACK
Default Uh Huh......
UH HUH............sure any locksmith can make a key
JESSERS does it with NOS original style keys, they have the blanks & correct locks etc............they can even rekey them etc...........
they are the KEY gooorooohs for the right stuff !!
ZIXXX PACKER
Old Oct 27, 2011 | 03:40 PM
white1984Z51's Avatar
white1984Z51
i am in the same situation with no door key. does the key to the door also work on the storage compartment, spare tire, and alarm?
Old Oct 27, 2011 | 03:43 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I am sure I am missing something here, but why buy a car without keys? If you haven't actually bought it yet, make the seller get the keys.
Old Oct 28, 2011 | 10:16 AM
det2orl's Avatar
det2orl
My ignition key works for the doors also. I thought they all worked like that.. The round key only works on the spare cover.
Old Oct 28, 2011 | 10:20 AM
CQRT's Avatar
CQRT
Round key is for doors and spare tire carrier, storage cubbie (or glovebox on newer models)
Square key is ignition.
Old Oct 28, 2011 | 10:25 AM
det2orl's Avatar
det2orl
interesting, not in mine, ignition key opens doors too.
Old Oct 28, 2011 | 10:34 AM
builder's Avatar
builder
I have a square key that opens the doors and works on ignition, a round key for the cubby hole behind the seat, and another round key for the spare tire lock.
Old Oct 28, 2011 | 01:56 PM
Easy Mike's Avatar
Easy Mike
...Round key is for doors and spare tire carrier, storage cubbie (or glovebox on newer models)...Square key is ignition.
Originally Posted by det2orl
...interesting, not in mine, ignition key opens doors too...
Key usage can depend on the model year.
Old Oct 28, 2011 | 02:41 PM
LancePearson's Avatar
LancePearson
Default maybe where you live...
I didn't find that to be true here in Va. In fact after contacting three and getting appointment cancelled I gave up and put new locks on both sides with new keys. They would never tell me why other than it takes essentially picking the lock then making a key to fit it on the blank and the businesses were all afraid I was somehow steeling the car even though it was in my garage and must have wanted no part of it.
None told me that directly but that was the net effect with three good locksmith companies.
Lance P.
Old Oct 28, 2011 | 02:46 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Lance P.
How were they to know whether you stole the house or not?
I was looking at houses in the Montgomery area. We went to one that was new and opened the garage to find 2 Corvettes in the garage. The builder was apparently hiding them from his wife or the IRS or both. I wanted to buy the cars, but not the house.
Old Oct 28, 2011 | 03:01 PM
qwank's Avatar
qwank
I know police cars only had one key. maybe someone along the line swapped out all the locks to use one key.
To Need new door key..
Old Oct 28, 2011 | 03:07 PM
MelWff's Avatar
MelWff
everybody stop and look at the original posting it is 5 years old!
Old Oct 28, 2011 | 03:19 PM
builder's Avatar
builder
At least someone used "Search" before posting.
Old Oct 28, 2011 | 04:27 PM
NassyVette's Avatar
NassyVette
LoL
