I got lucky today!
Old Nov 25, 2006 | 12:05 AM
Crazy81's Avatar
Crazy81
Default I got lucky today!
Yes! It's true! I finally got to spend some time with her alone, and after I pulled the carpet and all the trim out, I found almost zero rust.(only minor suface rust)
I couldn't believe it. I figure now I'll take a wire wheel to all the metal to clean off the old glue, paint and dirt, and the squirt a coat of epoxy primer all over the inside.
BTW- Any suggestions from you fella's that have been here already would be great.
Old Nov 25, 2006 | 04:05 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
You got lucky? C3 owners are different i guess.
I get the creeps when i see a car torn apart like that, thinking about the thousands of hours that will go into putting it back together.
But if that's what does it for you, have fun.
Old Nov 25, 2006 | 04:24 PM
Restorod '79's Avatar
Restorod '79
My son and I just saw these pictures and said "Remember when it looked like that!" You've got plenty to do this winter. I ended up with a bushel basket full of wires that were no longer needed. Good luck!
Old Nov 25, 2006 | 05:52 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Been there.......Take your time and think it through. You'll probably need more parts than you are aware of but better to do it now than rip it apart again later.
Don't ask me how I know
What do you guys think?
Old Nov 25, 2006 | 10:59 PM
roger55's Avatar
roger55
Be sure to check the area underneath the upper fender bonding brackets. It is a notorious spot for birdcage rust to begin.
Old Jan 26, 2007 | 09:59 AM
MorpheusGPR's Avatar
MorpheusGPR
What are you guys using to remove the old glue that is stuck to the fiberglass? I have some small sections of carpet and glue that did not come out with the carpet.
Old Jan 26, 2007 | 08:42 PM
javier's Avatar
javier
Looks awsome I hope mine looks that nice when Im done
Old Jan 26, 2007 | 08:55 PM
81cali's Avatar
81cali
Dean,
Now I understand what you meant by "she's in pieces". Good luck there, she sure will be needing your undivided time.
Old Jan 26, 2007 | 09:55 PM
682XLR8's Avatar
682XLR8
Try a heat gun and a putty knife
Old Jan 26, 2007 | 09:58 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I wonder if you could use a wire wheel on a high speed drill and get it done quicker? Any one try it this way?
To I got lucky today!
