Rear end assisstance needed
I am just wondering if there is anything else I need to watch out for before taking it apart. There is a carbon mono-spring on it. Do those bolts have tork specs?? Thanks, Ron
Just mark the positions of the control arm bolts in the bracket under the diff. Same goes for trailing arm shims, if you remove them. Most likely you'll need a new alignment afterwards, but you can get close. Maybe some of the guys have a really good method for home alignment, so you can keep that money in your pocket.
