Front Spring Pocket Cracks!!
Old Nov 28, 2006 | 12:33 PM
chadman's Avatar
chadman
Default Front Spring Pocket Cracks!!
I just discovered that the front spring pockets (in the frame) have some cracks in the metal just above where the springs rest. I guess I need to have those welded up?? Anyone else run into this issue and how did you fix it? Don't want the spring to eventually break thru!!
Old Nov 28, 2006 | 03:22 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Switch to coil-overs then it won't matter.
Old Nov 29, 2006 | 02:26 PM
chadman's Avatar
chadman
Thought of that but dont the top of the coils on the coilovers rest in the same pocket on the frame? The ones from Speeddirect.com seem to work that way.
Old Nov 29, 2006 | 02:42 PM
chevy69's Avatar
chevy69
St. Jude Donor '08
Sounds like a job for the welder to me.
Old Nov 29, 2006 | 05:30 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
get rid of the coil springs:http://www.vbandp.com/detail.aspx?ID=514
Old Nov 30, 2006 | 08:19 AM
MN80Vette's Avatar
MN80Vette
Default Front monospring
The front monospring conversion from VBP does not use the upper spring pockets at all. It uses the lower A-arm and lower A-arm mount on the frame.
Old Nov 30, 2006 | 09:55 AM
rihwoods's Avatar
rihwoods
Had similar issue on 78 SA drivers side..but it was a thin plate connecting pocket to cross member..ground it clean & welded the 3" crack...has not been an issue for over a year now...this is not uncommon,btw..
Rich
Old Nov 30, 2006 | 09:59 AM
Twin_Turbo's Avatar
Twin_Turbo
Wether you use the spring pocket or not, it's still a structural aprt of the frame and with the frame flexing the cracks will expand, weld it up!
To Front Spring Pocket Cracks!!
