grille replating
Old Nov 28, 2006 | 10:23 PM
early71's Avatar
early71
Default grille replating
My rt side front grille is in need of new chrome.I used a shop in NJ for my rear bumpers some years ago and would use them again.Here's my question,I am assuming that the entire piece is dipped,if so how do i go about restoring the black areas? These are the '70 style,no screw holes.thanks,JC
Old Nov 28, 2006 | 11:07 PM
68/70Vette's Avatar
68/70Vette
Don't quite understand. Here's a best try answer. The front grills (left and right) on the 1970's were cast aluminum and then they were chrome plated. For restorers this is a problem. There's not many chrome shops that can replate aluminum. To repair a used grill, your used grills have to electrolytically stripped of chrome/nickel/copper and then polished. Next they have to be first anodyzed. The plating process will needs to put copper over the aluminum, but the since the two metals are electically differenti an conductive anodyzing coating must be applied to the aluminum before the copper is applied. This conductive anodyzing processing is something that most chrome shops cannot do. However, once done the standard copper/nickel/chrome plating process follows. ....This my best understanding. I'm not an expert. Maybe someone has better knowledge and can fill in.
Old Nov 29, 2006 | 12:04 AM
Muddywaters's Avatar
Muddywaters
Mask all the non chrome areas off and shoot it!! Muddy
Old Nov 29, 2006 | 11:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Muddywaters
Mask all the non chrome areas off and shoot it...
A DIY project.
Old Nov 29, 2006 | 12:59 PM
pwsusi's Avatar
pwsusi
can someone post a closeup pic of what the grill is supposed to look like? On my 71 the chrome is decent...but on the bottom surface looks like it was black but it is chipping and it looks chrome underneath. i'm not sure what is supposed to be chrome and what's supposed to be black. I wanted to try to paint mine too....heck of a lot cheaper than buying new ones...couldn't believe how expensive replacements are.
Thanks,
Paul
Old Nov 29, 2006 | 03:48 PM
Butch R's Avatar
Butch R
I had my grills done last year, not many shops will do them. My shop charged $175.00 each and then I had to do what Muddy said.......
mask & shoot. The catch is they were not sprayed black from the factory, they are a greyish color. I did a search and found the correct color. This photo may help
Old Nov 29, 2006 | 04:48 PM
jnb5101's Avatar
jnb5101
by mask and shoot, i assume you are referring to paint.
a dumb question, but exactly what type of paint do you recommend?
thganks
jeff
Old Nov 29, 2006 | 08:20 PM
Butch R's Avatar
Butch R
Jeff,
I found the correct color on the forum........It was a dupont color, I went to my local supply house and found a color in spray can form that is almost exact.....(only the NCRS guys will know)
It is Dupli-Color Import Auto Spray dark grey # 8800564, I know the color is almost perfect because I bought two new bumperettes and they have a painted area next to the chrome and it looks great!
Oh and buy the way mask & shoot does mean spray paint
Good luck with your project
Butch
Old Nov 29, 2006 | 09:18 PM
dennis's Avatar
dennis
Had the grill formula for a long time. posted awhile back
Gray: Dupont 863-42103 to match WOA-3406" (one paint dealer reports to match WOE-340 in 1998) This spec, which is off the original print, may mean little to a Dupont supplier. Use code 9931 below for current (in 1999) match.
Use primer/sealer first then:
use Dupont code 9931 at 5% gloss level. (a flattener will have to be added to achieve this level) This code also includes an additive that will yield the rough surface of the gray area.
Upon calling Dupont directly, the Dupont Number 863-42103 is not found in their data files,but the Old Stock# Dupont code 9931 is, and is superceded by their new number for DK GRAY METALIC 723199 and that formulation date was 8/2/1990.Both paint codes were acrylic laquer,or Lucite.
The paint shops reccommend a color photo to match the existing color,since laquer here in N.Y. is no longer available.The paint can be made in a Base Coat Clear Coat.
Dupont was kind enough to fax the ingredients of the Grey 723199.Their phone number is 1-800-338-7668.
Old Nov 29, 2006 | 09:50 PM
Green73's Avatar
Green73
I've had better luck just spraying everything and then wipe with a rag soaked in mineral spirits for the area that doesn't need paint, usually just the raised area. Works great for redoing your rally hubs too.
Old Nov 30, 2006 | 07:21 AM
jnb5101's Avatar
jnb5101
thanks, butch and dennis
jeff
To grille replating
