My right headlight is slow to rise, sometimes won't rise. So I lubricated all light mechanisms, and it helped a little. I'm running a large duration cam, so I hooked the vaccum source for lights to my reserve can. Helped greatly. But, the right light is still slower to rise than left. Does anyone have a wiring and vacum diagram for the lights?Any ideas? Thanks, Chris
I had a similar problem, as it turned out the actuator was fine, but the seal at the front was worn out. I would test the actuator with a vacuum pump before going through the vacuum lines.
