Can someone help me decode my differential. I found two sets of numbers/letters,here they are as best as I could read them.
On the back upper is 3871375, on pass side is K or R A8 or 48, really hard to read that one. Ant others to look for?
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
68-69 rear end CODES:
AK= 3:36 SB
AL= 3:08 P SB
AM= 3:36 P SB
AN= 3:55 P SB
AO= 3:70 P SB
AP= 4:11 P SB
AS= 3:70 P SB AT= 3:08 HD P 427 " MINE" 427 / 400 TRI POWER 1968 4SPD
AU= 3:36 HD P 427
AV= 3:08 P 427
AW= 3:08 HD P 427
AX= 3:36 HD P THM 427
AY= 2:72 HD P THM 427
AZ= 3:55 HD P 427
FA= 3:70 HD P 427
FB= 4:11 HD P 427
FC= 4:56 HD P 427
LATE 69 TO 70 USED 3 LETTERS ALL STARTING WITH A "C"
SB = SMALL BLOCK
HD = HEAVY DUTY
P = POSI
THM = TURBO HYDROMATIC
From: Show me a cold beer and I will show you a happy man Maryland
not a pro, just trying to help so dont flame me...In my book I have it should read a number like AK 0621 W. The first letters determine ratio as follows
AK 3.36 not posi
AL 3.08 posi
AM 3.36 " "
AN 3.55 " "
AO 3.70 " "
AP 4.11 " "
AS 3.70 not posi
AT 3.08 H.D. posi
AU 3.36 H.D. posi
AV 3.08 posi
AW 3.08 H.D. posi
06 21 would be month and day of production an W is warren plant.
think you need to get the rest of the #s
Huh? Am I looking for a differant number somewhere else..
THOSE CODES ARE STAMPED ON THE BOTTOM OF THE REAR END DIFF CARRIER JUST FORWARD OF THE REAR END COVER.
YOU WILL NEED THE CAR IN THE AIR TO VIEW THIS.
68-69 PRODUCTION CODES CONSISTS OF A NUMBER FOR THE SHIFT THAT PRODUCED THE UNIT, 2 OR 3 LETTERS THAT ARE THE RATIO CODE THE DATE PRODUCED MONTH/1-12/DAY/YEAR AND A SUFFIX LETTER FOR THE PLANT THAT PRODUCED THE DIFF.
