Radiator options
Old Dec 10, 2006 | 09:24 PM
britvette's Avatar
britvette
Default Radiator options
I think I may have a hole in my rad
What are my options now - except changing the rad
What about something like radweld? Good / bad?
Any insight would be much appreciated
Old Dec 10, 2006 | 09:26 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
if you have a hole, there are only two options IMO
1. change it for a new one
2. change it for a new one
Old Dec 10, 2006 | 09:40 PM
rihwoods's Avatar
rihwoods
Radweld,Barsleak,etc,may slow/stop leak,but cooling will diminish as lower tubes get clogged up...
Old Dec 10, 2006 | 09:45 PM
blueray72's Avatar
blueray72
and 3. upgrade
Old Dec 10, 2006 | 10:35 PM
Russ T Gate's Avatar
Russ T Gate
If you want your car orginal have it recored, if not check with DeWitts and get a radiator that works.
Good luck
Russ
Old Dec 11, 2006 | 01:01 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
CALL DEWITTS !!!
OR CLICK HERE >>>>>>>>>>>> http://www.dewitts.com/
thay are AWESOME to deal with, & excellent quality !!
Old Dec 11, 2006 | 04:06 AM
Kalway's Avatar
Kalway
Pretty much a waste of time to bother trying to fix the leak.
If you can afford it, you've got dewitts.
If you're on a budget, like me, you can get a northern that'll fit fine too. PM me if you want details on it, Tom gets all whiney when I post a link.
Tom's is a bit better quality, but there's nothing wrong with using a Northern, and not a universal one like the one he uses in his comparison.
Old Dec 11, 2006 | 08:40 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
DEWITT'S
Old Dec 11, 2006 | 08:59 AM
Crunch-o-Matic's Avatar
Crunch-o-Matic
I ponied up and got the be cool from JEGS and add elec fans myself. Expensive radiator but I got every bit of what I paid for.
Old Dec 11, 2006 | 09:19 AM
rihwoods's Avatar
rihwoods
I spent some time deciding which way to go...Copper/Brass vs aluminum...I had good service from my original C/B...my replacement C/B in pic below only lasted 4 years...turns out,it was a Chinese core...thinner materials,etc...
Go to Dewitts site,as they have U.S. made copper/brass cores,and of course, excellant aluminum radiators...the advantage of aluminum is it disapates heat much quicker...
Old Dec 11, 2006 | 09:51 AM
Jims79's Avatar
Jims79
if its a large hole you should replace the rad. I purchased one from Be-Cool nice but $$. Ecklers & Mid-America have good replacement rad from $500 to $600 range. But I also fixed one that had a pin-hole leak with barsleak. It stopped the leak and did not effect the cooling.
It depends on the size of the hole & the amount of antifreeze on the garage floor. You can put the Barsleak in and use it until you decide to buy and how much you want to spend. I use to think this was a bubba fix and I would never use it until I saw a local GM dealership using it. The manager who was a friend of mine told me that it was GM approved.
Old Dec 11, 2006 | 12:39 PM
markdtn's Avatar
markdtn
Get a new one from DeWitts and be done with it.
Old Dec 11, 2006 | 05:13 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Thanks for all the comments.
Old Dec 11, 2006 | 09:00 PM
78Vette-SA's Avatar
78Vette-SA
Tom, got my new rad you sent today. It's a work of art. Thanks much for the quick turnaround!
Joe..
Old Dec 11, 2006 | 09:36 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Old Dec 11, 2006 | 10:24 PM
71rdster's Avatar
71rdster
If your car is NCRS quality you may want to seek out a rebuilder to have your radiator recored (Dewitts I think), or gat a quality "Direct Fit" replacement from Dewitts. Hmm, does that name seem to keep coming up?
To Radiator options
