look at this hood?
Old Dec 10, 2006 | 11:27 PM
mod81's Avatar
mod81
Default look at this hood?
is it just me or is the hood way off center on this car, there is one picture of it head on, i dunno what happened here. http://cgi.ebay.com/ebaymotors/1979-...QQcmdZViewItem
Old Dec 10, 2006 | 11:32 PM
DVNTST8's Avatar
DVNTST8
From: if you have a ? on my avatar, please contact me directly, you spineless twit
St. Jude Donor '09
It isn't you, it looks off center from here.
Old Dec 10, 2006 | 11:33 PM
Topless75's Avatar
Topless75
Blowers, well...at least that type, don't sit centered on the engine.
Regardless...whadda POS. $36k?
Old Dec 10, 2006 | 11:34 PM
mod81's Avatar
mod81
wierd
Old Dec 10, 2006 | 11:36 PM
Topless75's Avatar
Topless75
Originally Posted by mod81
wierd
Werd.
Troy.Blackburn's Avatar
Troy.Blackburn
It's definately off center... My guess would be that it's intentional for better road visibility for the driver.
Old Dec 10, 2006 | 11:54 PM
pef427's Avatar
pef427
Yep, thats just about the way mine sat from the factory. Off center and pointing towards the passenger headlight. I left my motor mounts loose and slotted my tranny crossmember and pulled it "almost" into alignment. The engine sits offset to the passenger side anyway but the "off-center line" look can be adjusted. This is very common with our cars, just hard to see when the hood is up cause it blocks the straight on view. I couldn't get mine completely straight because the driveshaft would have contacted the tunnel. Makes it tricky when your building a custom hood.
-P
Old Dec 11, 2006 | 12:49 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
look at the hood ? the entire car is a P.O.S & HARD to look at...........!!!
Old Dec 11, 2006 | 05:58 AM
Secret Squirrel's Avatar
Secret Squirrel
Yeah it's off centre, whats your point? It's factory...............
Have you ever looked at the position of your own engine?
Old Dec 11, 2006 | 06:01 AM
Secret Squirrel
Guy may be member here and love his car just as you love your's
Old Dec 11, 2006 | 06:28 AM
parkerracing's Avatar
parkerracing
I wouldn't run him for pinks....unless you have another ride home.
Old Dec 11, 2006 | 07:22 AM
rihwoods's Avatar
rihwoods
The yellow vette blower (below)is off center to pass side about 3/4" I think...
Rich
Old Dec 11, 2006 | 07:29 AM
427SIXPACK's Avatar
427SIXPACK
How did i know you would show & put your 2 cents in regarding MY post & noone elses ? HUMMMMMMMMM ?
Old Dec 11, 2006 | 07:34 AM
Secret Squirrel
Do you have tunnel vision?
Vision impairments must be going around. I'd swear that in your profile it used to say that you was a member from around August\September this year?
I guess we'll have to live with our impairments.
EDIT:Seems i may not be impared at all, thank goodness for that 'cause i'm only a young bloke.
http://forums.corvetteforum.com/show....php?t=1489470
Old Dec 11, 2006 | 08:58 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Except the hood I like it, the color is not my cup of tea but not the worst I've seen....
I wonder why they didn't make that scoop wider so that it can be centered ???
Here's a photoshopped version of the photo, looks pretty good....
Old Dec 11, 2006 | 09:23 AM
Crunch-o-Matic's Avatar
Crunch-o-Matic
If you look at the engine position in our cars they are all mounted towards the pass side.
(I read his info in a magazine article [Car craft, Hot Rod, or other,] so take it for what it is worth).
Apparently, back in the day someone noticed and asked GM WTF? What GM said the reason was, and the real reason, are two different things:
GM said it improved the balance, therefore improving handling performance. Typical BS answer from engineer and general public is happy.
Real Answer -- apparently, poor planning on the part of design engineers lead to mounting the engines to the right allowing necessary clearance for the steering anchor/box.
Cheers,
Crunch
To look at this hood?
