Need 69 engine numbers checked
Old Dec 18, 2006 | 08:27 AM
Bangkok Dean's Avatar
Bangkok Dean
Default Need 69 engine numbers checked
A friend just picked up a 69 Coupe with a 4 bolt main 350, how can he tell if it is the original block? Cast numbers top drivers side 3970010, stampings front boss V0806HZ.
Old Dec 18, 2006 | 08:42 AM
69'Silver's Avatar
69'Silver
My Black Book shows that the cast number is from a 1970 SB.
Old Dec 18, 2006 | 10:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
HZ for '69 designates the 350/300hp engine (base) with automatic transmission. Check the pad again. There should be a second number (VIN derivative) stamped on the pad.
Old Dec 18, 2006 | 10:21 AM
Bangkok Dean
yes there is an other number I will try to get it I did not know that the 69 came with 4 bolt mains.
Old Dec 18, 2006 | 10:26 AM
SoCalErv's Avatar
SoCalErv
Army
Good site for block and head numbers is www.nastyz28.com
I would also check the casting dates on the block. You have a good block number and assembly date but you need the vin number that matches in that year and a casting date.
To Need 69 engine numbers checked
