Key Stuck in the Ignition HELP!
Old Dec 20, 2006 | 03:29 PM
1975Stingray's Avatar
1975Stingray
Default Key Stuck in the Ignition HELP!
HELP my key is stuck in the Ignition . The Car still turns over and shuts off but the key will not come out! I have a 75 Convertible. Any suggestions of what to try? Thanks
Old Dec 20, 2006 | 03:33 PM
lvrpool32's Avatar
lvrpool32
do you have the trans lock detached?? is the auto in reverse?? is the manual trans in reverse??
There is a lever on the top of the steering coloumn inside the engine bay, that is normally connected to the trans via an armoured cable, check the lever is all the way towards the top (towards the brake booster).
Nick
Old Dec 20, 2006 | 03:37 PM
Durango_Boy's Avatar
Durango_Boy
Go to a hardware store like an ACE or something similar. Get a small tube of graphite powder. Cut the end of the tiny tip off, and squeeze a quick squirt of powder in the lock on top of the key and beside it or wherever you can get it in. Then just work the key a few times. Push it further in and out as far as it'll go. Start the car and shut it off a few times. Just work it.
It may not work, but it's worth a shot.
Old Dec 20, 2006 | 03:49 PM
1975Stingray
Man you guys rock; It's an Auto so I'll check the top of the steering colume, thanks lvrpool.
After that if that does not work I'll try the graphite powder, thanks Durango!
I'll post back tomorrow. Tom!
Old Dec 20, 2006 | 04:56 PM
Durango_Boy
Good luck, and may the Farce be with you.
Old Dec 21, 2006 | 06:50 AM
Jim Shea's Avatar
Jim Shea
There is a backdrive cable on the automatic trans as well. The lever on the steering column (out under the brake booster) must be in the full UP position in order to be able to get your ignition key to rotate all the way to OFF-LOCK and be able to remove your key.
Replace or fix the cable. Or remove the cotter pin, remove the cable and fix the lever in the full UP position permanently. Just be aware, with the lever always full UP, you can now turn off your engine, lock up your steering wheel, even while driving down the road. Not a very smart thing to do, but the backdrive cable on auto and manual trans Vettes prevents that from happening.
Here is a link to all you ever wanted to know about GM steering column/transmission shift interlock systems.
http://jimshea.corvettefaq.com/wp-co...tems27JL04.doc
BTW, a good lubricant for the ignition lock cylinder is a drop of synthetic engine oil on the tip of your ignition key. Just work it into the lock mechanism.
Merry Christmas,
Jim
Old Dec 21, 2006 | 02:07 PM
Durango_Boy
Merry Christmas,
Jim
That works okay? I'd heard it can cause a buildup of dust and grime creating a goop in the lock cylinder. The graphite is dry, so it may not adhere as long, but it doesn't build up.
Old Dec 21, 2006 | 04:59 PM
Jim Shea's Avatar
Jim Shea
That's what the engineer at Saginaw told me. They don't make the lock cylinder, but they install and ship lock cylinders in a lot of their steering columns. So they have a lot of contact with the lock cylinder manufacturerers.
Jim
Old Dec 21, 2006 | 06:05 PM
Durango_Boy
Jim
Hmm...I guess it can be chalked up to what an individual wants to use. Either is fine I guess.
Old Dec 21, 2006 | 09:42 PM
SILVERSIXX's Avatar
SILVERSIXX
Old Dec 21, 2006 | 09:50 PM
76project's Avatar
76project
You said the car turns off but is the key turning all the way back? Can you turn the key past off to the accessory? If you can not turn it all the way back it is in the linkage, If you can turn it all the way back it is in the cylinder itself. If it is in the lock cylinder it could be the buzzer switch. They have been known to break and bind up things. You may have to pull the cylinder and get a new one.
Old Dec 21, 2006 | 10:19 PM
68/70Vette's Avatar
68/70Vette
There is a backdrive cable on the automatic trans as well......
.. Just be aware, with the lever always full UP, you can now turn off your engine, lock up your steering wheel, even while driving down the road. Not a very smart thing to do, ..........
Jim
In trying to check out some teething problems with a new L88 clone engine I took it out on the freeway and did a brief full throttle acceleration in fourth gear. Unfortunately the throttle stuck in the full open position. Not a good thing to experience. The engine was just going crazy with power and my speed was really going up into dangerous regions. I quickly realized my options were to push in the clutch and destroy the engine, or just turn off the ignition. I was afraid that turning off the engine would lock the steering. I I told myself that turning off the ignition was not supposed to lock the steering so I did it. A great relief, the engine turned off and the steering did not lock. The throttle soon unstuck and I drove home, although no more full throttle accelerations until I replaced the throttle spring.
Old Dec 21, 2006 | 10:26 PM
Jim Shea's Avatar
Jim Shea
The positions in the ignition switch are: START, RUN, OFF, OFF-LOCK, AND ACCESSORY. With the lower lever in any position but full UP, you should only be able to turn the key as far as OFF. You should not be able to get to OFF-LOCK.
Now with the lever full UP, you can easily pass from OFF to OFF-LOCK and now the lock bolt moves rearward in the column head and engages a notch on the locking plate. Steering wheel is locked!
Old Dec 22, 2006 | 01:45 AM
gkz's Avatar
gkz
My '75 has the opposite problem: I can pull the key out anytime, any position. Not only that, but the switch rotates around and around if you so desire. Another thing to work on--someday.
Old Dec 22, 2006 | 09:41 AM
cknorr28's Avatar
cknorr28
Don't know if this is what is wrong with yours but mine had the same problem. My Dad took the steering column out of the car checked everything and still couldn't get the key out. While he had the steering column on the workbench he turned the sleeve right below the ignition
( i think it was for the telescopic option) and the key came right out. Don't know if that is what really fixed it but it worked.
To Key Stuck in the Ignition HELP!
