Interior windsheild molding installation.
Old Dec 25, 2006 | 11:12 PM
ImBatman's Avatar
ImBatman
Default Interior windsheild molding installation.
The wife bought me a big box of toys from Doc Rebuild. I got the header and side post interior moldings out to test fit them tonight and noticed that the holes were not drilled for mounting them. I had to replace the top of my WS frame due to rust and the new one does not have the holes drilled in it either. What is the best way to fit the moldings and locate the proper hole locations in the moldings so that I don't mess them up?
BR
Old Dec 26, 2006 | 12:08 AM
SIXFOOTER's Avatar
SIXFOOTER
clamp a laser pointer in the car pointing in the correct hole location in the frame. then put the interior piece in place and mark and drill the plastic at the dot...spot on
Old Dec 26, 2006 | 05:06 AM
WESCH's Avatar
WESCH
Hi
Sinse the windshield frames have no holes, it is easier.
Just drill the holes into the moldings , clamp the moldings in situe and drill mark through the molding holes.Only mark, don't drill through. Remove the moldings and now drill htrough the frames. Otherwise you might damage your new modlings when the drill bit breaks or ....
You couldn't get a better fit.
The laserpointer method is perfect if the holes in the windshield frames already exist.
Merry Christmas. Günther
Old Dec 26, 2006 | 09:03 AM
srosa75's Avatar
srosa75
What a great idea....
Old Dec 27, 2006 | 11:04 PM
SIXFOOTER's Avatar
SIXFOOTER
I didn't invent it, but I have sure used it a lot
To Interior windsheild molding installation.
